| Forum topic by StreamDreamer | posted 264 days ago | 834 views | 0 times favorited | 10 replies | ![]() |
264 days ago |
Hey everyone. Obviously, new guy here. I’m really wanting to attempt to make a fly box. I get how to use a template and plunge router to trace out the “hollowed” out portions, but I cannot for the life of me figure out how to hollow out the rest without cutting all the way through the lid or bottom! Been on the web for 4 hours now, and can’t find anything! HELP PLEASE! Thanks! |
10 replies so far
#1 posted 264 days ago |
You need to fix a guide bush to your router that will follow the template you have created. If you gradually increase the depth of cut you will achieve your designed depth and not go through the base of your box. -- It always looks better when it's finished! |
#2 posted 264 days ago |
I get that part… I just mean hollowing out the rest of the surface. For example.. if i’m wanting to make a 5” x 3” box.. and i plunge out 1/4” deep, and trace out the square shape inside the lid, the is still a lot of surface left inside the lid that would mash down the flies on the bottom of the box. My question is, how or what kind of tool do I use to get rid of the rest of the center surface? Hope that makes sense.. like I said, newbie. Don’t know sh** :) |
#3 posted 264 days ago |
Start in the middle and go round(in a spiral-ish fashion) and round till you get to the edge of the template. This way you have one large pocket, rather than a moat. Am I understanding your question? -- Backer boards, stop blocks, build oversized, and never buy a hand plane-- |
#4 posted 264 days ago |
Rance I believe is correct. -- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability |
#5 posted 264 days ago |
Rance shows you the right way, all you have to make sure is that your router base plate is bigger than the pocket area you need to route out. Basically the middle of the pocket can be dome “freehand” if the router base is big enough. -- Roger-R, Republic of Texas. "Always look on the Bright Side of Life" - An eyeball to eyeball confrontation with a blind person is as complete waste of Time. |
#6 posted 264 days ago |
Oh, listen to what JR45 says about cutting in small depths until you reach the desired depth. Do not expect to route everything out at full depth. -- Roger-R, Republic of Texas. "Always look on the Bright Side of Life" - An eyeball to eyeball confrontation with a blind person is as complete waste of Time. |
#7 posted 264 days ago |
My guitars feature a Tonal Chamber that is sometimes almost 12” across, and 8-9 inches wide. I start in the MIDDLE with a plunge router and work my way out, so my base is always on the outside edge. I would do any kind of box this way also, even if I had a bushing setup that would hit a template around the edge -- Paul, Tennessee, http://www.tsunamiguitars.com |
#8 posted 264 days ago |
You can build a larger sub-base for the router and use a bearing-guided You can also make the template so it is defines the outer limit |
#9 posted 264 days ago |
Awesome guys. Thanks a bunch. The only thing I could think of was to use the router and cut in strips until it was all gone. Didnt know if I should use a forstner bit or what. That helps a ton! Thank you all!! |
#10 posted 264 days ago |
Show us the finished product! -- It always looks better when it's finished! |
| Forum | Topics |
Woodworking Skill Share
8850 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1600 |
3595 |
15985 |
Hand Tools
2102 |
Jigs & Fixtures
501 |
Wood & Lumber
2911 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2778 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6136 |
