Delta table saw on CL
Forum topic by rhybeka posted 237 days ago 412 views 0 times favorited 5 replies Add to Favorites Watch
View rhybeka's profile
rhybeka
161 posts in 1292 days
237 days ago
So I happened on this this morning and was wondering if its a good deal? I think it is but I’m not sure since delta fas always been out of my range :) any input is appreciated! http://columbus.craigslist.org/tls/3300941048.html
-- aspiring jill of all trades
5 replies so far
View toolie's profile
toolie
1112 posts in 799 days
#1 posted 237 days ago
no. the better delta saws usually have solid front guide tubes. i’m pretty sure the lower end deltas had split front guide tubes and that might even be a direct drive motor. for between $200 and $300, you should be able to get a 113 series c-man or ridgid 10” left tilt CI contractor saw ($50-100) and add a delta t2 fence from tools-plus ( http://www.tools-plus.com/delta-36-t30.html ) for <$160. relatively inexpensive but reliable and,once dialed in, accurate set up. i have 2 of them and really like them.
View WDHLT15's profile
WDHLT15
687 posts in 647 days
#2 posted 237 days ago
At 1 HP, I believe that it would be under-powered.
-- Wood-Mizer LT15
827 posts in 664 days
#3 posted 237 days ago
I, too, think I would keep looking. I’m fairly certain that’s a direct drive saw.
-- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard)
rhybeka
#4 posted 237 days ago
Thanks guys! I’ll keep searching :) Toolie, thanks for the heads up!
View knotscott's profile
knotscott
4202 posts in 1546 days
#5 posted 237 days ago
That’s likely the old TS350, which was a compact saw with a similar skeleton as the TS300 “Shopmaster” line, but had an unusual direct drive induction motor, as opposed to belt drive. Claims of it being “heavy duty” are wishful thinking….guess it’s all relative. The motor is small, the table is only 22” deep, and the fence isn’t too good. $200 should find you a nice full size contractor saw (27” deep) with a 1.5 to 2hp belt drive induction motor, and hopefully a better fence.
