Pocket Screws or not, frame and panel home chest
Forum topic by Swyftfeet posted 264 days ago 618 views 0 times favorited 10 replies Add to Favorites Watch
View Swyftfeet's profile
Swyftfeet
165 posts in 368 days
264 days ago
Topic tags/keywords: question
This is my first real project and am unsure which way to go here. Everything has been running pretty smoothly so far but I am a bit hesitant to continue.
Making a larger frame and panel hope chest. Carcass is 24×48x24, with a 26×50 top. Frame and top made out of 4/4 black walnut. I am using Whiteside Router bit kit for beaded panel construction. All the end grain on the rails will be getting grooved(routed?) to fit into the stiles, the total length of contact between the rail and stile is 4.5”. Is the surface area large enough for just glue(using titebond liquid hide), or should I go out and get a Kreg kit to put some pocket screws in, or is that overkill?
Also, the bits came with 1/4” cutter for the panels, and the Ash ply that I purchased is only 3/16ths thick, is this normal? I’m a little nervous that the panels will have too much play front to back and make the construction look a little more novice than what I would like. What can be done about that? I was thinking shimming in the inside to make sure the panels all sit towards the outside? any thoughts?
Thanks!
Brian
-- Brian
10 replies so far
View Milo's profile (online now)
Milo
813 posts in 1516 days
#1 posted 264 days ago
Can you post some picture so we have a better idea of your project? I’m terrible at descriptions. :(
-- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear...
View JSB's profile
JSB
540 posts in 275 days
#2 posted 264 days ago
Having built 3 chests using pocket screws…I say do not use them if they will be visible. I made my blanket chests with a pocket hole skeleton and secured panels on the inside. Check them out on my project page. Some visuals may help. But again, I say no pocket holes if they will be seen.
- Jay
-- Jay - http://www.jayscustomcreations.com or YouTube.com/jayscustomcreations
View Bill_N's profile
Bill_N
191 posts in 476 days
#3 posted 264 days ago
I love pocket holes myself, as long as they are not seen
I would suggest making the groves on the table saw
-- I have the Saw Dust Fever
View rockindavan's profile
rockindavan
257 posts in 833 days
#4 posted 264 days ago
If I’m getting it correctly, you have pretty much a door making router bit kit with the small “tenon” that fits into the groove. Instead of beefing it up with unsightly pocket screws, buy a cheap doweling jig and strengthen it with a couple of those, then it is invisible.
View oluf's profile
oluf
252 posts in 1236 days
#5 posted 264 days ago
For your loose panels in the 1/4 ” groves you can put it all togather and than caulk the panels into the groves from the inside. Use clear silicone caulk and wipe the joint smooth with a wet finger. Keep your finger wet and wipe off the excess on a shop rag.
-- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it.
View MT_Stringer's profile
MT_Stringer
789 posts in 1428 days
#6 posted 264 days ago
or you can buy a set of under size router bits made for plywood. I got my set from Woodcraft. Made by Whiteside.
Swyftfeet
#7 posted 264 days ago
Thanks folks! I am currently on the road, so I cant post any pics. I think I feel good enough to continue!
-- Brian
View Rb12's profile
Rb12
31 posts in 425 days
#8 posted 263 days ago
I for one, and I think many others, made their first project(s) way burlier than nescessary. I used enough screws in some of my early cabient/chests to support an elephant :) Pics would help, but generally tennoning is pretty strong and you don’t need screws as backup, but I echo the doweling if you are concerned.
If you don’t want to buy a new router bit for the panels, you can shim it, I have done that usually as a backup for not being very exact. You could also use a table saw and make a couple passes and adjust the fence one blade length to get the right size channel
View Loren's profile
5028 posts in 1845 days
#9 posted 263 days ago
Pocket screws will make the construction look novice for sure.
View BHolcombe's profile
BHolcombe
44 posts in 272 days
#10 posted 261 days ago
I’d pass on pocket screws in favor of tenons or dowels.
