CutList Bridge version 2.2 released
Forum topic by Chiefwoodworker posted 09-27-2012 03:08 PM 3554 views 0 times favorited 1 reply Add to Favorites Watch
View Chiefwoodworker's profile
Chiefwoodworker
149 posts in 3407 days
09-27-2012 03:08 PM
Hi Folks,
In the process of trying to find a fix for black text fields when on a MAC, I discovered I inadvertently created a bug in CutList Bridge version 2.1 that renders adding to the materials list inoperable. I am really upset with myself because I didn’t test all aspects of the tool before releasing it. I only tested those areas where I thought I touched with code changes. Stupid me! I have fixed this problem in release 2.2 which you can download at http://www.srww.com/blog/?p=1918 . Sorry for the screw up.
I still haven’t implemented a solution for the black text fields when using CutList Bridge on a MAC with Safari release Version 5.1.7 (6534.57.2). The problem is that input fields end up with black backgrounds making it impossible to for user’s to see what they are inputting. So if you have that version of Safari you will have this problem with my (and others) scripts. This started with the latest update Version 5.1.7 (6534.57.2) of Safari. I am told by experienced bloggers on this site that the combination of Mount Lion OS and the latest release of SketchUp solves this problem. In my next release I will implement a solution suggested by John Boundy that should work for older versions of MAC O/S.
-- Joe.....
1 reply so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3741 days
#1 posted 10-27-2012 03:19 AM
As these systems get easier to use it seems coding for them gets more intricate. I hope the solutions work out.
