Chisel Size, Ray Iles Mortise
« back to Hand Tools forum
Forum topic by corpmule posted 09-27-2012 01:28 PM 1803 views 0 times favorited 5 replies Add to Favorites Watch
View corpmule's profile
corpmule
57 posts in 2349 days
09-27-2012 01:28 PM
Topic tags/keywords: question chisel traditional
I’m new to woodworking and, my inexperience leads me to ask some possibly stoopid questions.
I purchased a Ray Iles 5/16″ mortise chisel. It just arrived yesterday, I haven’t used it yet but, it looks like a really well made, awesome tool.
However …
The packaging on the chisel said it’s 5/16″, just as I had ordered. But, when I measure the blade (tip) and, measure a small indentation in a piece of wood (created with slight hand pressure), the measuring tools read 3/8″ (6/16″).
I guess that ain’t really a bad thing, I can still use it but, is that normal for a tool to be out of the advertised dimension that much? Is there a variance in the actual tool size that should be expected? Or, is it most likely just a mistake in the packaging? Maybe someone put the wrong tool in the wrong package?
Thanks for any advice offered.
5 replies so far
View crank49's profile
crank49
4032 posts in 3142 days
#1 posted 09-27-2012 05:42 PM
What did you measure it with?
Calipers or a micrometer, or with a ruler?
Even if it were metric approximation of English units 5/16” is 7.94mm so an 8mm would be the metric “equivalent”.
But 3/8” is over 9.53mm and is often equated to a 10mm chisel. That’s a whole size range off.
View paratrooper34's profile
paratrooper34
915 posts in 3123 days
#2 posted 09-27-2012 06:13 PM
Corpmule, you got the wrong size somehow (wrong packing, packaged on a friday?). A 5/16 mortice chisel should be 5/16. It is a whole size off, metric or standard.
-- Mike
corpmule
#3 posted 09-27-2012 09:36 PM
I measured it using the US measurement system, with both a ruler and dial calipers.
I measured the tool physically at the blades edge and, by pressing an indentation into a piece of wood, then measuring the indentation.
It’s actually just a hair (1/64?) short of 3/8 (6/16). I feel kind of bad …kinda nit picky but, why is a 5/16 and a 3/8 size offered? Why is there a choice between them? If it didn’t make a difference, there wouldn’t be a choice …right? :)
I just spoke with them on the phone, they’ve offered to replace it. The problem is, they are out of stock and they don’t know when they’ll be restocked. So I guess either use this one, or do without until they’re restocked and I get the replacement. I ‘spose I could buy a “stand in” off of ebay for the mean time.
View Brett's profile
Brett
661 posts in 2854 days
#4 posted 09-28-2012 12:28 AM
These chisels have received good reviews, and they’re affordable:
http://www.leevalley.com/US/wood/page.aspx?p=66737&cat=1,41504
-- More tools, fewer machines.
View BrownDog's profile
BrownDog
9 posts in 2447 days
#5 posted 09-28-2012 12:50 AM
You got the wrong size somehow.
I have the complete set of Ray Iles mortise chisels and they are all the correct size.
Just send it back and get the right size sent to you.
