Jet 16-32 Drum Sander Conveyor Belt ISSUES
Forum topic by Lance posted 09-27-2012 01:48 AM 13968 views 0 times favorited 17 replies Add to Favorites Watch
View Lance's profile
428 posts in 2462 days
09-27-2012 01:48 AM
I’m having trouble getting my conveyor belt to track straight without pulling towards the left. I’ve followed the manual, called Jet’s support tech and I’ve even broken the bolt from tightening it too much. The tech told me to take the belt off and switched it around, figuring the belt was maybe the issue, nope, it keep pulling towards the left. (If the belt pulled towards the RIGHT, then we know it’s the belt, but it didn’t) It says to tighten the side that it’s pulling towards and loosen the other. The problem lies when it keeps pulling towards the side that I can’t tighten anymore! Reason why it broke. The tech told me if switching the belt didn’t help to call back and he’d send me a new belt, but my final thought is that the whole bottom Sand Smart unit needs to be replaced. There is something twisted or wrong with it b/c it pulls hard to the left after 2-3 minutes, this unit has less than an hour of total use. Brand NEW!!
Flipped the belt, still didn’t work, this wear and tear is from less than 20 passes through the sander, that’s not normal is it????
The bent/broken bolt, I had to break it to get it off!!
Any suggestions??
-- Lance, Hook'em HORNS! ""V""
17 replies so far
View bruc101's profile
1197 posts in 3478 days
#1 posted 09-27-2012 02:09 AM
I’ve got a 16-44 Performax I bought in 1994 and it’s never tracked dead on. I finally gave up on it and let it track where it wanted to. The conveyor belt is actually nothing more than a sanding belt for a wide bet sander.
We changed the original belt on the sander last year so I suppose it doesn’t owe me a penny for lasting so long. The sander has been used almost on a daily basis since I purchased it mostly sanding face frame pieces and wide panels when the wide belts are busy. It’s our go to sander most of the time because of fast paper changes and ease of operation.
Someone else may have a solution for yours.
-- Bruce Free Plans
View gfadvm's profile
14940 posts in 2626 days
#2 posted 09-27-2012 02:25 AM
Lance, This has been a constant problem with my Jet drum sander. I tried to get my money back (no luck there). They sent me a new belt which helped some but it still requires constant adjusting. Those white ceramic ‘guides’ under the table are completely useless and I don’t use mine. Sorry I don’t have an answer but I can commissurate with you.I really hated those cheesy little ‘wrenches’ on the adjustment bolts so I cut them off and use a T handled allen wrench to adjust them now. I bought an older Craftsman 18/36 drum sander with the rubber conveyer belt and it works perfectly! Go figure. Maybe a rubber conveyer belt would fix ours? But not sure where to find one. Please keep us updated as you are not the only person with this issue.
View Gshepherd's profile
1727 posts in 2138 days
#3 posted 09-27-2012 02:51 AM
I have had SuperMax sander for about 7 years now. They are pretty much same design so I will mention a few things and hope it helps…. First make sure the drum is in correct alignment. If it is not it will tend to push to one side or the other. Straight edge, yard stick or what ever to make sure it is properly lined up. once that is checked. Loosen both sides…. Both….. then tighen back up and you should not have to get real crazy here just enough to keep the belt from slipping…..
get the conveyer belt moving medium speed but be ready to turn off if it is way off, slowly tighten up a bit more, key here is not to over tighten, over time you can tighten up a bit cause the belt will stretch some. I have the rubber belt, pricy for a 37in but been working fine for over 5 years. Does yours only have adjustments on one end? Or both. I agree that the bottom cermaic guides suck…. If it is aligned you do not need them if the belt is off, well you be better off playing pickup sticks with your butt cheeks than to rely on those darn things.
Check drum alignment first….. My first guess is it is off and considering the open end may have a little to much flex in it or just off some…. When it is running without a board on it does it seem ok? But when a board starts going through it start to wonder on you…... Tell me if any of this helps….
-- What we do in life will Echo through Eternity........
View pinebeetle's profile
15 posts in 2006 days
#4 posted 09-27-2012 03:09 AM
I had the same problem with mine; I finally got disgusted and bought an aftermarket rubber belt from now no more tracking issues… Don’t know if it would fix yours but to me it was worth trying… They run about 90$ tho…
#5 posted 09-27-2012 03:30 AM
Gshepherd, “playing pickup sticks with your butt cheeks”- ROFLMAO!
View Loren's profile
10115 posts in 3584 days
#6 posted 09-27-2012 06:50 AM
do you have the ceramic guides?
View Roger's profile
20916 posts in 2740 days
#7 posted 09-27-2012 01:39 PM
I just aquired a 16/32 Performax, and I did a very minor adjustment of the same reason. You do have to tighten one side while loosening the other, and do it in small increments, like 1 or 2 flats (the nut), at a time, then let it run for a minute, then speed it up and let it run for a minute so it aligns itself. I’m just grasping at straws, but, maybe the drum is not parallel, and pullin it to one side? Hope you get it figured out. I know you’re frustrated, and you should be, being that it is brand new. Their customer service hopefully will fix you up. Good luck.
-- Roger from KY. Work/Play/Travel Safe. Keep your dust collector fed.
View UncleSnail's profile
54 posts in 2976 days
#8 posted 07-01-2013 09:22 PM
Hi All, Interesting dialogue here. I also just bought a new Jet 16-32…took delivery just a few hours ago. And the conveyor belt tracks to the right or opposite of the open side. No adjusting works…tightening, loosening…not even cussing at it. I called tech support and he told me to loosen the rollers and drop them (the rollers) down to below the table (his words) and said that would solve my problem. Huh? The belt rollers are NOT on swivels but he insisted they were. In other words, we had a communication issue. I also turned the belt around to no effect. This tracking issue has nothing to do with my sanding drum. It tracks without the sanding. I also ditched the ceramic guides. A bad joke. ‘Expecting a call from a service center tomorrow. I have high hopes. I also expect to win the lottery tomorrow. So there ya go. I am thinking either the after market rubber conveyor or perhaps just ignoring the issue as mentioned earlier will be my course. I feel for ya Lance. No, I would not recommend this to a friend…nor an enemy for that matter.
-- Dale, Michigan, objects scare wife scares me too.
#9 posted 07-01-2013 09:23 PM
Loren, you can have my guides. LOL
#10 posted 07-01-2013 09:48 PM
Correction: My sander tracks to the open side (left) not the other side as I said earlier.
View Dion1234's profile
3 posts in 1607 days
#11 posted 10-29-2013 03:10 PM
Just purchased the Jet 16-32 3 days ago and I am having the same problem the conveyor belt keeps going to the left, now I am confused and don’t know what I should do to correct this problem. Does anyone know where to get the rubber belt?
View dahenley's profile
136 posts in 2029 days
#12 posted 10-29-2013 03:25 PM
View Howie's profile
2656 posts in 2859 days
#13 posted 10-29-2013 04:18 PM
Guess I got lucky when I bought my Jet 16/32. Been using it for two plus years and it was perfect right out of the box.
Only problem I had was trying to figure out that stupid little hook for changing the sanding belts.
-- Life is good.
#14 posted 10-30-2013 04:59 PM
Thank you for the site, dahenley
View Phil Rasmussen's profile
Phil Rasmussen
10 posts in 1727 days
#15 posted 12-22-2013 04:31 PM
I have a 16-32 and it tracks fine. However I do have problems with the tacking of the sanding belt on the drum. But that is another story.
Here’s my take. So many of us believe that when we get something right out of the box it should work 100% without having to do adjustments. That just ain’t so! We don’t jostle our equipment around in the shop but the shippers certainly do, so I never take it for granted that all is ok when I pull it out of the box.
Many of the responses have been to adjust the belt with the adjusting bolts. There has also been mention of the drum alignment. Yeah that could be the problem.
However no one has said anything about two other possible problem areas.
So first check to see if the bed is properly seated. If you have extended the bols as far as they will go, see if you and adjust the bed some.
Second, check to see if you have proper tension on the rollers on the drum head. These can skew the board and in turn shift the belt tracking.
There will always be 101 things that can go wrong but never forget that there is also the 102 item and above that we rarely think of.
-- Phil Rasmussen, US Army-retired The Mountain WoodworkerHendersonville, NC
