What is this thing? A Mystery Measuring Gauge
« back to Hand Tools forum
Forum topic by CueballRosendaul posted 240 days ago 1033 views 0 times favorited 32 replies Add to Favorites Watch
View CueballRosendaul's profile
CueballRosendaul
218 posts in 312 days
240 days ago
I don’t remember where I picked up this little thing, but it’s been in the bottom of my toolbox beckoning me to figure it out. It’s a little over 4” long, solid brass with a steel slot gauge. The numbered notches don’t correspond to either fractions of an inch or metric scales. The slot marked 1 is about 3/64”. I thought maybe a wire gauge, but a #12 wire fits into slot 7 or 8 perfectly. The numbers on the center slot are opposite, where the slot gets smaller as the number gets larger. There is a funky Asian looking symbol on the reverse side. Any ideas?
-- Matt CueBall Rosendaul. I don't think I've ever had a cup of coffee that didn't have cat hair or sawdust in it.
32 replies so far
CueballRosendaul
#1 posted 240 days ago
Hmm, looks like when I upload to photobucket I should shrink and crop my own pics, they don’t do a very accurate job of it. You get the idea however.
View Loren's profile
4898 posts in 1820 days
#2 posted 240 days ago
Perhaps something to do with typesetting.
View cutmantom's profile
cutmantom
188 posts in 1207 days
#3 posted 240 days ago
my guess is for measuring sheet metal in units of “Gauge”, the center part could be for wire, put it in the top hole and slide down till it stops and read the measurment
View Charlie's profile
Charlie
686 posts in 458 days
#4 posted 240 days ago
the numbers are going in the wrong direction to measure gauge. 18 gauge sheet metal is THICKER than 24 gauge. Same with wire. 8 gauge wire is thicker than 18 gauge.
View mtenterprises's profile
mtenterprises
623 posts in 865 days
#5 posted 240 days ago
This is kind of a shot in the dark but to me it looks like a pin gage that would be used by a locksmith to measure the pins used in a lock. But the numbers don’t corrispond with lock pins unless there was at one time a different numbering method. Even that thin tapered slot in the center could have been used to measure the thin “master pins”. Would really like to see some better pictures.
MIKE
-- See pictures on Flickr - http://www.flickr.com/photos/44216106@N07/ And visit my Facebook page - facebook.com/MTEnterprises
CueballRosendaul
#6 posted 240 days ago
I’ll try to upload a short video tomorrow.
View OnlyJustME's profile
OnlyJustME
1385 posts in 549 days
#7 posted 240 days ago
Could it be to measure what size drill bit you need to use to tap a hole? I think when i’ve purchased a tap and bit set before the bit was numbered instead of an actual size like 1/8.
-- In the end, when your life flashes before your eyes, will you like what you see?
View Annaa's profile
Annaa
5 posts in 257 days
#8 posted 240 days ago
I’ve no idea about it.Perhaps it’s a kind of measuring tools.
-- Orange 50-60# GTX 31" draw speaker tripod http://www.sencart.com/pair-professional-speaker-stands-tripod-heavy-duty-new_p51530.html
View bluekingfisher's profile
bluekingfisher
809 posts in 1151 days
#9 posted 240 days ago
Its a hair comb for folks with very thick hair ;-)
-- No one plans to fail, they just, just fail to plan
CueballRosendaul
#10 posted 240 days ago
Here’s a video.
CueballRosendaul
#11 posted 240 days ago
the numbers are unevenly spaced and some are heavier than others, which leads me to believe they were struck by hand with a punch. The notches are also not completely uniform in shape and appear to have been cut with a file. Perhaps its an ancient Chinese secret.
View Gshepherd's profile
Gshepherd
1363 posts in 373 days
#12 posted 240 days ago
Is it a old Thread guage? Does the sizes seems to be the same in groups of 3…...
-- What we do in life will Echo through Eternity........
View Roger's profile (online now)
Roger
9207 posts in 976 days
#13 posted 239 days ago
I have no idea… lol
CueballRosendaul
#14 posted 239 days ago
not a thread gauge as far as I can tell. Not in groups of three either. The number 2 slot is not twice as large as the number one. Each slot is slightly larger than the next, but only by a couple thousandths.
If the crowns between the grooves were pointy it’d make a dandy beard comb.
View grfrazee's profile
grfrazee
219 posts in 311 days
#15 posted 239 days ago
My initial thought is that it’s a thickness gauge. If you look at the #12, it looks to be about 7/64 (which is ~ 0.1094”), and 12ga steel is 0.1046”.
However, steel gets thicker as the gauge number get smaller, so that can’t be right.
Maybe it’s some old standard that was dropped when the metric system was adopted?
-- -=Pride is not a sin=-
showing 1 through 15 of 32 replies
