BLO?
Forum topic by WoodCop posted 09-27-2012 12:05 AM 2179 views 0 times favorited 18 replies Add to Favorites Watch
View WoodCop's profile
WoodCop
29 posts in 2234 days
09-27-2012 12:05 AM
Topic tags/keywords: blo boiled linseed oil finish poplar red oak
Hi All,
I’ve been lurking on this site for about 6 months nows while I create my woodshop. I am in the process of putting together a workbench, which the top consists of red oak T&G flooring over 2×4s, wrapped by poplar. I am interested in finishing the top with a finish that is durable, repairable and doesn’t take away from the beauty of the red oak. I’ve done a sample board on the oak of BLO, Danish Oil and straight Poly. I like the way the BLO looks and the fact it penetrates the wood itself, however, am a little leery of it on the poplar. Has anyone had any good experiences with BLO on poplar?
Thanks for the insight, its making my head spin!
Mike
-- “Things may come to those who wait...but only the things left by those who hustle.”
18 replies so far
View Don W's profile
Don W
18707 posts in 2562 days
#1 posted 09-27-2012 12:19 AM
I’ve used BLO on poplar quit a bit. I don’t think it “pops” popular like it will oak, and it will turn it a yellowish color. If that’s what you want, then use it. If you want the poplar to keep the milky white, use something else.
WoodCop
#2 posted 09-27-2012 12:24 AM
What is that “something else?”
View benchbuilder's profile
benchbuilder
284 posts in 2444 days
#3 posted 09-27-2012 12:30 AM
I have a workbench made of poplar and used BLO on it for the past 25 years. its very dark now and the grain is very hard to see, this may be good on the edges wher you will get a lot of wear, but it does darken over time. Remember, what ever you put on the top of your workbench you have to put on the bottom side of the top to help it stay stable
Don W
#4 posted 09-27-2012 12:30 AM
It really depends on what you want it to look like. To darken it a little, I’d use a colored danish oil. You could also just wax it. I like poly over poplar to. You will find a love hate relation with poplar. I really like it. I cut a lot of native poplar with my sawmill, so I use it a lot.(well a lot compared to some other wood, I don’t really use anything a lot anymore)
WoodCop
#5 posted 09-27-2012 12:45 AM
Im looking to keep the color of the poplar light to give a nice contrast to the oak top. I would need something that will absorb and harden in the wood, like a BLO, however not change the color.
View bandit571's profile
bandit571
19960 posts in 2677 days
#6 posted 09-27-2012 01:05 AM
To not change the colour, use a water -borne poly like the one from Minwax. Goes on milky-white, dries crystal clear. Low to no odor, apply with a towel wrapped around a squeegee. Re-coat in a few hours. Poly-crylic I think is the name.
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3152 days
#7 posted 09-27-2012 01:32 AM
I don’t care for poplar just because of how plain it typically is…and therefore oil doesn’t really do much for it, like Don mentioned above. But if you like the look, then do it. I’d be more inclined to use a wood like pecan/hickory for that same whitish look. Of course, maple as well, but that’s so unoriginal! ;)
My problem is using the poly on a work bench. It will do nothing to really protect your bench from the types of abuse your bench will take and will look ugly pretty fast. Then, it’ll be a pain to strip it.
I’d just go with oil and wax. That way, you can easily replenish the finish on occasion without the painful need of stripping.
I’d use tung oil, however. IME, it doesn’t shift the color to the yellow as much as BLO, which is why I don’t typically use it. Plus, it seems to harden more than the BLO. You might try some polymerized tung oil, which is the 100% stuff thats been cooked off a bit, akin to BLO. It helps the drying time, which still takes days and maybe weeks. BLO will dry much faster by comparison.
BTW, typical danish oil uses tung oil. I don’t see the advantage of using BLO ahead of it. But since I’ve never thought to try that, I just might be incredibly close minded. ;)
-- jay, www.allaboutastro.com
WoodCop
#8 posted 09-27-2012 01:46 AM
That leads me to my next issue. How does one know in what order to layer finishes? i.e., shellac under a poly, or a danish oil under/over BLO?
View Charlie's profile
Charlie
1100 posts in 2280 days
#9 posted 09-27-2012 01:58 AM
Waterlox original. Done
Cosmicsniper
#10 posted 09-27-2012 02:49 AM
I use shellac in between everything. Oil first for best saturation. As for Danish oil, that depends on the Danish oil. A true oil/varnish blend would go on after the BLO if you want to apply both. This is because once the varnish part hardens, the BLO can’t really do anything. If its a Danish Oil like Watco that actually has no varnish in it – check the product data sheet – then it probably doesn’t matter the order. I’d still put put down the BLO first just in case.
Shellac under poly poses no problems…that’s more of a myth, IMO. Just use dewaxed shellac.
Still, as many have said, you are really over thinking this. Squirt the sucker with your choice of oil and be done with it. Reapply regularly for everlasting beauty. The beauty of the poly topcoat will be short lived, at less if you use your work bench the way I would.
View Dusty56's profile
Dusty56
11819 posts in 3682 days
#11 posted 09-27-2012 03:09 AM
I can’t think of any reason to use more than one type of oil finish….obviously you want a finish that soaks into the wood and becomes one with it , not one that lays on top of the wood (ie: poly) just to get nicked and chipped if you plan on using your bench.
If you look up “Danish” oil , you will see that it is mostly solvent 60% and 20-30% Linseed oil and the balance are chemicals. So , essentially , you are putting Linseed oil on twice , and most of the “D” oil is just evaporating around you : )
View Woodknack's profile
Woodknack
11601 posts in 2374 days
#12 posted 09-27-2012 03:11 AM
Woodcop, you’ll be way ahead to pick up a book on finishing. I have Flexner’s but there are other good ones out there.
Cosmicsniper
#13 posted 09-27-2012 03:33 AM
Ditto on the Flexner text. Highly recommended.
View Clint Searl's profile
Clint Searl
1533 posts in 2355 days
#14 posted 09-27-2012 04:13 AM
If you want a drying oil finish, use real tung oil. BLO is only good for starting fires.
WoodCop
#15 posted 09-27-2012 10:58 AM
Sounds like picking up a book is the best place to start, since I have the time as only the top portion of my bench is complete. The legs and stretchers won’t be started until next week. Lastly, as far as finishing BOTH sides of the bench, I covered 2×4 w oak flooring. Since only the oak flooring will be getting the finish, I don’t believe the underside of the 2x’s need a finish, correct?
