| Forum topic by shelly_b | posted 236 days ago | 631 views | 0 times favorited | 9 replies | ![]() |
236 days ago |
I am trying to decide which kind of dust collectorto get and am getting confused lol. I know cyclonics are suposed to work better but when i compare the cfm with the same hp, the cyclonics always have a lower cfm, so how can they work better? Or do they just not get clogged as fast so suction doesnt decrease like the single stage? Thanks! |
9 replies so far
#1 posted 236 days ago |
The cyclone actually decreases the efficiency of the system due to centrifugal force, therefore lowering the cfm. But the benefits of the cyclone separator are enough to justify a loss in cfm. -- Rex |
#2 posted 236 days ago |
This is a hot topic with lots of opinions. Fine woodworking did a feature article a while back (maybe a year) and they concluded that pretty much any cyclone works better than a regular dust collector. Air flow may be a bit lower due to the resistance of the cyclone, but it doesn’t drop off as the filter loads up like a bag/canister type. Bill Pentz’s site has enough information on the topic to make your head spin, but well worth the time to read. -- John |
#3 posted 236 days ago |
To further clarify: the purpose of a cyclone separator is to increase the effectiveness and lifespan of your filter, not to make your DC suck harder. Only a bigger/better motor/blower can do that. Another benefit of a cyclone is that they are usually easier to empty than a DC without a cyclone. -- Rex |
#4 posted 236 days ago |
Good DC requires moving lots of air, and then separating the dust from the air stream. If you have a unit that does that, it really doesn’t matter whether it;s a single stage or a cyclone. Cyclones have a lot of advantages, though. Because they increase drag on the system they often have bigger motors and impellers, but because the stuff doesn’t hit the fan (so to speak) the impellers can be designed for maximum air flow. Single stage impellers have to be designed to withstand impacts. A well designed cyclone will not clog, one not-so-well-designed can send a lot of fines into the filter creating a need for frequent cleaning, mine is such a model. If you haven’t visited the Bill Pentz site, do so. But to avoid spending the next year there trying to catch up on the techno-babble just go to the FAQ section and peruse. Follow up on what’s of interest to you. One tidbit, more than any aspect of woodworking, DC has a broad range of opinions of what’s good and what’s not. That’s because the opinions are formed on expectations that differ greatly, from those who believe the DC is to keep them from sweeping up the floor to those who believe it needs to capture and contain every possible spec of dust. Choose where you are on that span to make your own assessment. -- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard) |
#5 posted 236 days ago |
Thanks thats what my guess was. If i were to get a single stage i would put a seperator on it and make it a 2 stage. I already have tje woodcraft one that goes on the big metal trash can…cleaning clogged filters is not on my list of favorite things to do lol |
#6 posted 236 days ago |
I’ve had my ClearVue cyclone and Wynn flilters for 2 years and never had to clean a filter. It still sucks like crazy. Most of the vendors don’t really report usable numbers on CFM. They often report CFM of the fan with no ductwork or load on the fan which is totally unrealistic, but it sells dust collectors to those who do not get into the details. -- Ed |
#7 posted 235 days ago |
I got tired of all the hype an built my own cyclone..been working two years wid no problems.. -- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA. |
#8 posted 235 days ago |
I built/added a Thien cyclone to my HF DC unit and while it does lower CFM, it also separates the dust/chips so much better that it was well worth the effort. An added benefit is the time saved in bagging your chips when using separator with your DC. The separator that I built was ugly but works so well that I have never had to replace it. -- HorizontalMike -- "Woodpeckers understand..." |
#9 posted 235 days ago |
thanks everyone:) some day i will build a bigger better one…but so much to do and so little time at this point, i’m just gonna have to use what works for now and upgrade what seems to need it most at the time. It has taken soo much longer to get my shop together than i originally thought, but i am slowly gettinig there. Jointer is the only thing i really NEED. Right now I have 2 shop vacs, and one has a oneida dust deputy on it. It works but dragging it around when I switch tools is a pain… |
| Forum | Topics |
Woodworking Skill Share
8790 |
Woodturning
220 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1530 |
3547 |
15767 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6156 |
