| Forum topic by Brett | posted 234 days ago | 1510 views | 2 times favorited | 10 replies | ![]() |
234 days ago |
I’ve seen many different plans for table saw sleds, some with one runner and others with two. And the runners themselves may be made from wood, UHMW, aluminum, or steel. Which configuration (one or two runners), and which material, do you prefer? -- More tools, fewer machines. |
10 replies so far
#1 posted 234 days ago |
Definitely 2 sliders. One slider can act like a fulcrum. Any lateral movement (pushing unevenly on one side for example) could lift it it out of the miter slot or eventually cause it to break loose. I made mine from maple and so far so good. It was easy to fit, easy to attach, easy to replace if I ever need to, easy to adjust after attachment to get that exact fit, and I had plenty laying around. I have not needed to make any adjustments for seasonal movement and it’s not showing any signs of excess wear. I would consider using WHMW as it is obviously more stable if I wasn’t so cheap. |
#2 posted 234 days ago |
I agree with 2 sliders. I used aluminum bar stock, then tapped the sides for nylon set screws for micro adjust capability. -- Paul, Clinton, NC |
#3 posted 234 days ago |
I concur with 2; too much chance of movement with one. I used two incra steel runners on my old sled, they worked well. I recently rebuilt my sled and used oak, they also work well. Toss up I’d say, and the oak is cheaper. I seen some posts on issues with plastic; it deforms a bit when you tighten down the screws and causes issues with fitting. Not a show stopper, but something to watch for. William Ng has a nice youtube video on making and adjusting a crosscut sled. Talks about best grain orientation if you’re making wooden runners, along with a lot of other things. Worth a look. http://www.youtube.com/watch?v=UbG-n--LFgQ&feature=g-user-c -- John |
#4 posted 234 days ago |
Paul, that’s a great idea. Where do you get the nylon set screws? do you find they wear down over time? |
#5 posted 234 days ago |
I’ve used hardwoods and also the UHMW runners , and I believe that two are best , but not always necessary depending on the size of your sled. If your sled is covering most of your table top , then certainly use two of them. I have a smaller sled that I square up cutting boards , etc., with and it is fine with just one runner : ) -- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did. |
#6 posted 234 days ago |
I would use 2 runners. I build a sled with UDMH runners. Tip on the material – check out mcmaster.com. They have this stuff for a decent price. I bought a 1’x2’ sheet of 3/8” thick material so I could make several TS accessories (other any accessory with a miter track). jmos’ comment about the plastic deformation is true, however it can be mitigated with some added functionality. I started with the large blank and drilled a few holes along one side 3/8” from the edge (half of the standard 3/4” miter track). I used #10 brass inserts in the holes. Then I ran the edge (trimming about 1/64”) through the table saw to remove any potential bulge from the brass inserts. I then cut the 3/4” runner from the large blank and waalaa, perfectly strait and flat with inserts. It’s a bit more work, but it also adds some benefit when you attach the runners to the sled. Often people will put the runner in the tracks with double sided tape and drop the sled on top, then screw it in. I put small counterbored holes in my sled. Drop the runners in the tracks, put the sled over it, then just screw it down with #10 screws. The screws and inserts can be found at McMaster for a couple bucks. I was also thinking about the fact that I may have to adjust my runners if I move from a warm and dry climate to a cold and wet climate (something that is very possible still). With the couterbored holes, I have just enough room to adjust the runners (won’t need much). My sled runs really smooth, I like the UDMH. It’s a bit more work, and a couple more bucks, but imo worth it. -- Jason |
#7 posted 234 days ago |
Regarding lumberjoe’s inquiry about the nylon set screws, they—and the taps—came from MSC Industrial Supply www.mscdirect.com. The aluminum bar stock came from Airparts Inc. at www.airpartsinc.com. I considered buying the ready-to-use miter bars from Incra, but I just felt like doing more of it myself. By the way, I’m not surprised to see so much interest in this thread. Certainly, the table saw and the crosscut sled are at the heart of many, if not most, shops. It’s easy to develop some real experience with various approaches. -- Paul, Clinton, NC |
#8 posted 234 days ago |
I have one steel runner and it does cause issues! I used this as it was ground to fit my table saw by a friend of mine who was a machinist about 40 years ago. Next time I will use two aluminum runners since aluminum on cast iron are good bearing surfaces! -- "I never met a board I didn't like!" |
#9 posted 234 days ago |
Thanks Paul. I’m going to consider that option. I agree with you 100%. A table saw sled opened up a whole new world of possibilities for me that were simply not possible before, or no where near safe. I have several sleds now and can think of a few more that would be useful |
#10 posted 234 days ago |
Two runners, aluminum. I like incra’s miter sliders or their glide lock bars. -- He who dies with the most tools... dies with the emptiest wallet. |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3541 |
15750 |
Hand Tools
2028 |
Jigs & Fixtures
494 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
