My shop is setup just about the way I want it (for now)
Forum topic by mbs posted 09-26-2012 04:42 AM 1733 views 0 times favorited 16 replies Add to Favorites Watch
View mbs's profile
mbs
1656 posts in 2938 days
09-26-2012 04:42 AM
Topic tags/keywords: workshop organize dust collection felder tip
There are a few things I’ve done that I really like and I would do over again. And a few things I would do differently. I guess this is the forum to share the good, the bad, and the ugly. Most of the ideas listed below were developed while I was working in a 2 car garage. I was fortunate enough to build a larger garage and incorporate many of the ideas. Setting up a shop is more of a continuous journey and not a discrete event. I’ll never be done. There is always something else I need (want) and something I need to sell.
The pics can be seen at “my workshop”
The good -
Position the saws, planer, jointer, shaper so the outfeed is in front of the garage door and you won’t lose valuable working space.. I realize this only works when the weather is nice and you have a large garage door to point them at.
Make a covered patio and supply electricity to it. It’s nice to work outside in the shade and it’s healthier too. Clean-up is easy with a leaf blower.
Put skylights in the shop to let in natural light. Supplement with a lot of T8 florescent lights
Make dedicated cabinets to hold items. e.g. plane cabinet, sanding cabinet, drill cabinet. ...
Learn how to make customized dust collection fittings. it will save you a bunch of money.
Mount your dust collector and compressor outside (if possible). They take up floor space and are noisy.
Put dust collection floor sweeps in the corners and blow the dust from one end of the shop to the other.
Plumb in a lot of electrical outlets (inside and outside) and install airlines to get to the major areas.
If you have both a radial arm saw and the miter saw build them on the same platform to reduce space.
Put equipment on good castors to move it easily.
The bad (what I regret):
I wish I would have put the dust collection piping and some electrical outlets in the floor. It would look nicer and be safer to work around.
Don’t install too many windows because they take up valuable wall space.
I would consider having a wood floor because it would be more comfortable than standing on concrete. I don’t have any experience with wood floors and I’m not sure they would withstand the weight of some of my tools.
I wish I would have purchased a 3 phase rotary converter and purchased 3 phase equipment. I believe three phase is less expensive and better than single phase. Higher end equipment is made with three phase power and it can be cheaper than single phase.
I made an office that I really don’t use. I would rather have the shop floor space.
Before I acquired some of the bigger tools there was enough room to park a car in the shop. Now I regret allowing a car there because my wife thinks it’s her parking space.
The ugly:
Don’t use the rubber flooring that I used. It shows all tracks and never looks good. I would use epoxy with sand next time.
I hope this helps.
-- Sorry the reply is so long. I didn't have time to write a short reply.
16 replies so far
View Surfside's profile
Surfside
3389 posts in 2172 days
#1 posted 09-26-2012 08:26 PM
Thanks for the tips!
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View whitebeast88's profile
whitebeast88
4128 posts in 2188 days
#2 posted 09-27-2012 12:06 AM
great tips and a beautiful shop thanks for sharing.
-- Marty.Athens,AL
View steamfab's profile
steamfab
76 posts in 2179 days
#3 posted 09-28-2012 05:40 PM
It’s always great to share a couple of good and not-so-good experiences with fellow lumberjocks. I appreciate your time for posting this.
117091 posts in 3575 days
#4 posted 09-28-2012 06:02 PM
Great looking shop with some outstanding equipment. I agree with most of your tips but I’ve found that having a Radial arm saw and a sliding compound chop saw on the same platform are troublesome and annoying, at least it was in my shop. I do have some of my DC, electrical outlets and air in the floor and it does make things much easier. As far as having wood floors goes if they are built the right way you can park a locomotive on them, many of the turn of the century factories had wood floors. Thanks for sharing your tips.
View RogerM's profile
RogerM
792 posts in 2397 days
#5 posted 09-28-2012 09:03 PM
Love your shop. My kind of guy!!!
-- Roger M, Aiken, SC
View mbs's profile
mbs
#6 posted 09-28-2012 09:13 PM
A1Jim,
I too have had problems with keeping the RA saw and the miter saw aligned but i think it’s worth the effort when compared to the extra space it takes to tbe saws on separate tables.
If the Felder works out as well as I think it will I may get rid of the RA Saw. About the only time I use it is when I need more than an 8” cut. The quality of the RA cut isn’t very good when compared to the miter saw or the felder.
View Moron's profile
Moron
5032 posts in 3892 days
#7 posted 09-28-2012 11:47 PM
loose the RAS, an electric chain saw is good enough.
3 phase converter is a must
you might grow to hate that plastic dust system, static charges, sparks, dust, impossible to ground (almost)
I disagree about windows on walls pending where you live because nothing compares to natural light and its free
albeit the concept of electrical outlets on the ground/floor is inviting, the practical application of such has its own problems, same for burying dust pipes…….a real PITA to remove obstructions.
Easy enough to lay solid wood flooring over the concrete and your right. 30 + years of standing on cement is hard on the feet, knees and hips.
Rip the office out ?
As for the wife’s car………..that problem will only get worse as the dust starts to seep into every crevice of her car.
You have a beautiful shop. Enjoy
View mbs's profile
mbs
#8 posted 09-29-2012 03:58 AM
Would solid wool flooring be much better than concrete?
View mbs's profile
mbs
#9 posted 09-29-2012 01:51 PM
I should have said – would a solid wood floor placed on concrete be much better? I was thinking of putting plywood over 1”x2” so there was some flex in the wood.
View mbs's profile
mbs
#10 posted 09-29-2012 02:12 PM
Moron
I could get rid of the office. I had some left over stone flooring material that I put down in the office that i would need to take up too.
My ras does compound angles but my miter saw doesn’t. If I get rid of the ras I will probably sell the miter saw and get a sliding compound miter saw. I need to sell a bandsaw too.
My point about windows is you can have too many. I have 8 sky lights that I love and about 30% to 40% of my wall space has windows or doors. Between the windows and dust collection drops there isn’t a lot of room for tall shelves or cabinets.
Moron
#11 posted 09-29-2012 02:18 PM
Plywood works, and a little flex is even better. Tools IMO, should sit on concrete or the weight of the tool should bare directly onto it, perfectly level and no flex.
never regret anything. If its good its wonderful. If its bad, its experience : ))
View AJswoodshop's profile
AJswoodshop
1057 posts in 2275 days
#12 posted 09-29-2012 02:25 PM
I have my table saw right by the garage door. So if I have a longer board, I can stand out in the driveway and rip it down, then I have a outfeed table for plenty of support.
Again, great shop!
Moron
#13 posted 09-29-2012 02:28 PM
My boss asked me if I wanted an office, one of those portable trailers that are parked at a job site. I declined as a simple set of box horses and a sheet of plywood suffice, and also lets me see whats going on around me, thus avoiding the less then perfect choices some trades make.
The only benefit I see in an office, is that the dust is kept at bay. As a rule, the office is invaded by wives and children and before you know it, it is ransomed for what could have been shop space.
Floor space is critical, as it enables one to make exactly what we buys tools for.
Moron
#14 posted 09-29-2012 02:30 PM
a table saw, especially yours, can produce perfect compound angles and a sliding compound miter saw can do the same
View mbs's profile
mbs
#15 posted 09-29-2012 03:12 PM
My other hobby is riding dirt bikes. I currently use my office to store my riding gear, file cabinet, and fridge. I haven’t spent the time to make it a good office or good floor space.
I’m hoping to dial in the felder this weekend. The slider is .020” above the cast iron table. I have a lot to learn to use its functionality.
