eliminating burn
Forum topic by wiser1934 posted 09-25-2012 03:09 AM 1778 views 0 times favorited 6 replies Add to Favorites Watch
View wiser1934's profile
wiser1934
524 posts in 3022 days
09-25-2012 03:09 AM
any input on getting rid of burn marks after routing a corner on a board??
-- wiser1934, new york
View cabmaker's profile
cabmaker
1667 posts in 2684 days
#1 posted 09-25-2012 03:53 AM
If your cutter is known to be sharp and you burned due to going slowly, just set it a hair deeper and make another pass at a faster rate. (Dont stop your cutting motion while bearing on the work piece)
View Clint Searl's profile
Clint Searl
1533 posts in 2236 days
#2 posted 09-25-2012 03:39 PM
Burns happen. Sandpaper or a scraper.
View ROB_IN_MN's profile
ROB_IN_MN
32 posts in 2022 days
#3 posted 09-25-2012 05:00 PM
don’t stop while the board is in contact with the bit. that’s what causes the burn. Slow, steady and don’t stop is the best way to avoid burns.
View Tennessee's profile
Tennessee
2672 posts in 2390 days
#4 posted 09-25-2012 05:06 PM
Some wood, like cherry or purpleheart, seem to burn no matter what. But like said above, steady, solid movement, never stopping is the trick. Also might want to do two cuts, as a deeper cut may bog down the router and slow down the cut, causing heat and burn. Just once you start, commit and don’t stop, or pull off if necessary to keep it from burning.
View NiteWalker's profile
NiteWalker
2736 posts in 2452 days
#5 posted 09-26-2012 12:18 AM
Most burning occurs from too slow of a feed rate with the router.
+1 on taking another light pass to clean it up. Keep the router moving at a brisk pace.
wiser1934
#6 posted 09-26-2012 01:54 AM
thanks evderyone
