Whether to use Pegged Tenons
Forum topic by MJCD posted 09-24-2012 05:40 PM 1738 views 0 times favorited 11 replies Add to Favorites Watch
View MJCD's profile
MJCD
541 posts in 2365 days
09-24-2012 05:40 PM
Topic tags/keywords: pegged tenons epoxy jatoba
Forum Members:
I need some advice …
I’m working on a large, Jatoba-based outdoor bench, which has 40 M&T joints – most of which are load-bearing (there are backrest slats which are not). The bench will be 100 lbs, all-in; and will be permanently outdoors – North East, US.
This is my first M&T project, and I’m unsure of how tight the Tenons need to be in the Mortises – the M&Ts are already created, and within my tolerances, I have a distribution of spot-on to somewhat loose (not that I have experience in these definitions); I believe it’s correct to say that none of them are either catastrophically loose or too-tight for the epoxy glue.
I’m using the West Systems G/Flex 650 epoxy as the adhesive, and I’ve researched the product as having excellent holding strength (greater than the wood, itself) & flexibility – that is, it’s not brittle to where normal racking and wood movement will result in failure.
The Tenons & Mortises are all 1.25” deep by 0.75” thick, and vary in width from 1.75” to 2.5” – these are Integral Tenons, not floating. My concern is that someone will try to lift it bench by an armrest or a back rail (both of which I would peg), causing the joint to fail – that is, the glue, alone, on one or two tenons may not be able to support the sheering effect of lifting 100 lbs.
My thought is to peg the corner tenons at 0.25” above the tenon base, with a 0.25 peg, and to do this while the project is glued & clamped-up.
As always, I appreciate the experience and counsel from the Forum.
Thanks, MJCD
-- Lead By Example; Make a Difference
11 replies so far
View Bill White's profile
Bill White
4928 posts in 3954 days
#1 posted 09-24-2012 05:53 PM
Not only will it aid in strength, it’ll look so darned GOOD. Get after it.
Bill
-- bill@magraphics.us
View MJCD's profile
MJCD
#2 posted 09-24-2012 06:03 PM
I should add, as an explanation, that the armrest is capped onto the front corner post, and the back rail is capped onto the back corner posts, so that trying to lift the bench by either of them places all of the force on the glue, not the tenon itself.
Bill – thanks for the quick response: I think is will, as well; however, I’m about a mile over my skill level already, and have concerns that if I keep ‘playing with it’ I’ll mess it up – with a smile. Thanks.
MJCD
View teejk's profile
teejk
1215 posts in 2678 days
#3 posted 09-24-2012 07:07 PM
pegged does add a great “old world” appearance but you do add another “rot” factor. I think I would go with counter sunk metal fasteners and fill with plugs do give the appearance of through dowels. NE USA is not really kind to anything left outdoors.
View MJCD's profile
MJCD
#4 posted 09-24-2012 11:46 PM
Teejk:
I hadn’t thought of that; and, I’ll have to.
Thanks.
View nwbusa's profile
nwbusa
1021 posts in 2280 days
#5 posted 09-24-2012 11:52 PM
If you decide to go with dowels to peg the joints, you might also consider using the “drawbore” technique. Marc over at the Wood Whisperer did a good video on the subject. Here’s the link: http://www.thewoodwhisperer.com/videos/drawbored-mortise-tenon/
-- John, BC, Canada
View HorizontalMike's profile
HorizontalMike
7754 posts in 2908 days
#6 posted 09-25-2012 01:56 AM
I would only add that you can actually wait for the glue to dry before adding either the dowels OR the screw/dowel cap. It won’t be going anywhere once the glue dries, and besides, the dowels are basically a backup/addition to the original M&T joint. Plus, it will make it much easier to drill the dowel holes without wet glue all over the place.
View MJCD's profile
MJCD
#7 posted 09-25-2012 12:31 PM
Great Advice – you’ve evidently been there a few times …
Marc’s video (thanks, nwbusa) is very helpful – how does he and halfinchshy have time to do these great videos? I’ll make 0.25” dowels/pegs from the Jatoba – this should address Teejk’s insight.
Thanks, again.
MJCD
HorizontalMike
#8 posted 09-25-2012 12:52 PM
John,
I took the time to watch the video link you attached. Very interesting concept though I was confused by just one claim. How is a “same sized dowel” actually “stronger” when it is drawbored rather than drilled and pinned? Like I said I like the concept, however I think the guy stretched the truth a bit with THAT claim. Tighter OK, stronger I don’t think so… but maybe there is something I am missing here. How about choice of dowel wood making the dowelbored joint stronger? Maybe…
View MJCD's profile
MJCD
#9 posted 09-25-2012 02:34 PM
For my part, I’ll defer to his experience, though I glossed-over that one. While the concept is interesting, I’m not going to ‘drawbore’ the tenons – with the epoxy and peg, if the joint fails, so be it – the joint isn’t part of a fallout shelter.
Thanks, again, for the great comments.
MJCD
View casual1carpenter's profile
casual1carpenter
354 posts in 2470 days
#10 posted 09-25-2012 04:21 PM
Mike, I think his thinking in stating that drawbore makes a stronger joint is the fact that in mechanically forcing the joint tighter and eliminating small movement or slippage it would decrease the fatigue failure rate. The drawbore technique was demonstrated on ‘the woodwright shop’ I believe, by a guy who does colonial era reproduction and museum work. If it makes a rock solid joint with no glue at all, then the finished joint with glue bonding and bridging any small gaps can only be better. At least that’s my take on it. My biggest concern would be just how much to adjust the hole alignment. I do not imagine if a little is good a lot is better. Wood species, moisture contents, etc could likely play a part if you look real close at small issues.
HorizontalMike
#11 posted 09-26-2012 01:23 AM
@casual1carpenter,
Hey thanks for confirming what I was thinking concerning these joints. I made knock down wedged dovetails on my WW-bench, but haven’t tried the permanent draw bored dowels. For me, it will probably remain a curiosity. At 60yr of age, I am expecting all of my “glued” joinery will outlast me and it will then be someone else’s problem IF my joinery fails.
And like you, I would be guessing “how much” offset to use, much less what woods to use this type joinery on…
