Drum Sander windings
Forum topic by Brookebond posted 09-24-2012 02:44 PM 1261 views 0 times favorited 6 replies Add to Favorites Watch
View Brookebond's profile
Brookebond
10 posts in 3026 days
09-24-2012 02:44 PM
Does anybody know if there is a formula for working out the cut-off angles for fitting abrasive paper to a drum sander. My problem is that I have not been able to get the paper at the same width as the one fitted to the machine when I purchased it, so cannot rely on using the same diagonal end cuts. I get the first end in but after winding I find that I am either too short or too long for the slot at the other end.
Any advice would be most welcome…
View Gshepherd's profile
Gshepherd
1727 posts in 2169 days
#1 posted 09-24-2012 07:40 PM
What size drum sander, I have a 13in and a 37 inch. Knowing what size someone could measure the length. So if yours is either a 13 or 25 or 37 I can measure for you if that helps. On the back of the replacement paper there are colored lines that I have to cut for what size I am needing. Brand name of your sander would be helpfull as well.
-- What we do in life will Echo through Eternity........
View Steve Peterson's profile
Steve Peterson
371 posts in 3050 days
#2 posted 09-24-2012 11:22 PM
Just guessing, because I have not actually tried it, but the length of the diagonal cut should be the same as the circumference of the drum minus about 1/8” to provide a small gap. Wind the paper around the drum until it hits the other end. Some widths will line up with the clip and other will not. It seems like you have to find the proper width of paper for it to work properly.
The popular drum sanders, like Jet/Performax, will have multiple suppliers competing to supply sandpaper in the proper width. What brand and size is your sander?
-- Steve
View lew's profile
lew
12019 posts in 3723 days
#3 posted 09-25-2012 01:17 PM
When I made my home made sander, I made a long strip of paper. Wound it around the drum, marked the ends, removed and used it as the first pattern.
Brookebond
#4 posted 09-26-2012 09:46 AM
Thanks for your responses. The dimensions of my Drum Sander are as follows:
Drum length 410mm – 16”
Circumference 426mm – 16 3/4”
paper width 82mm – 3 1/4”
I will try cutting the diagonal the same size as the circumference and see what happens. What is strange is that I tried cutting the diagonals the same as the paper that was in the sander when I got it. The paper I am using now is perhaps 1/8” narrower than the original but when I tried to fit it the end was nowhere near the clip.
Brookebond
#5 posted 09-26-2012 09:48 AM
Footnote….
The Drum Sander is not one of the common popular brands. It comes from Poland but is designed along the lines of the Jet models.
Steve Peterson
#6 posted 09-26-2012 05:31 PM
If your paper is 1/8” narrower than the original, then it would seem like the easiest solution is to increase the gap by 1/8” when winding. Otherwise, the end will land in the wrong place and will not line up with the clip.
A more extreme solution would be to cut another slot in the drum so you can move the clip to the location that works with the paper you have.
-- Steve
