Brainstorm with me, Please!
Forum topic by Milo posted 09-24-2012 02:36 AM 1499 views 0 times favorited 27 replies Add to Favorites Watch
View Milo's profile
869 posts in 3250 days
09-24-2012 02:36 AM
Topic tags/keywords: question
Hey Gang,
Well, I’m moved to Florida, and my beautiful shop is no more. ARGH! :(
I hope to get the ACC of my neighborhood to allow me to build a new shop in my back yard. LOTS of hoops to jump through there. I think the key will be to attach it to the house somehow…
ANYWAY, the FIRST problem is this. I have an 8’x10’ shed in the spot where I want to put the shop. I have to move it. It’s too heavy to lift, and I don’t really want to take it apart if I don’t have too.
Does anyone have any ideas on how I can move it? I need to more it about 75 ft with a 8 – 10ft elevation.
I’m considering finding someone with a truck and winch to pull it across the yard, and I would put some kind of roller under it so it would roll easily. WHAT kind of roller I am still trying to decide.
As always, your thoughts are appreciated.
-- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear...
27 replies so far
View Arlin Eastman's profile
Arlin Eastman
4139 posts in 2492 days
#1 posted 09-24-2012 02:42 AM
Flatbed trailer and wench it up on rollers underneath
-- Please help me help other Vets click..> is always the right time, to do the right thing.
View Grandpa's profile
3259 posts in 2606 days
#2 posted 09-24-2012 02:47 AM
You might lay some wood beams on the ground to make the path. Lay them like rails on a train track. Them you could use smaller rollers like pipe to move the shed. You would only need enough beams and roller to put under the shen and some in front then you could move them as you moved the shed off them. Carry those to the front and keep pulling it across the yard. We don’t have the soft sand and ground like you do there but it works well where I live.
View JJohnston's profile
1622 posts in 3222 days
#3 posted 09-24-2012 02:48 AM
Boom truck.
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
View hamburglar's profile
42 posts in 2030 days
#4 posted 09-24-2012 02:48 AM
At the job I just left part of my duties was operating the 15 ton boom truck. (Old dinosaur of a thing really)
But…. In the 4 years that I worked for that company I must’ve moved a handful of sheds like the one you describe or larger. Try calling your local lumber yard to see if they might have something similar. If so, I bet they charge around $100 an hour, and it wouldn’t take but 20 minutes if you prepped it beforehand.
View Joe Lyddon's profile
Joe Lyddon
10047 posts in 3983 days
#5 posted 09-24-2012 03:05 AM
View longgone's profile
5688 posts in 3239 days
#6 posted 09-24-2012 03:12 AM
Years ago I had 10×12 shed moved. The guys used a flatbed tow-truck with a cable wench…the type where the back lowered to the ground so a vehicle could be pulled up on it… They had 4” pvc pipe they used to roll it on…right on the grass and they just kept picking up each piece of pvc as it came out the back and moved it to the front. It was very easy for them to do.
View whitebeast88's profile
4128 posts in 2121 days
#7 posted 09-24-2012 03:33 AM
most towing companies will move the building for a reasonable could jack the building up and place long pipe or long post under and roll you would just have to keep moving the pipe til you got there.
-- Marty.Athens,AL
View Milton Toal's profile
Milton Toal
107 posts in 2002 days
#8 posted 09-24-2012 06:05 AM
Pipe as rollers works. If you can jack up the shed one side at a time and put timber lengthwise along it and also on the ground – you need three pieces per side so that as you roll off one you move it up to the front. Short lengths of 2” gal water pipe are not expensive. Depending on how you rig it, you can tow it with a stationary 4WD with a winch, either fron the timber you set on the base of the shed or another piece across the back and winched from both sides.
-- Milton Toal, Doncaster, Melbourne Australia.
View HorizontalMike's profile
7749 posts in 2845 days
#9 posted 09-24-2012 01:39 PM
Not to throw a wrench into this, but do be aware of where your in-ground pipes are in particular sewer/septic lines and/or other drainage lines. Not sure how Florida regulates such, but do be aware. FWIW, this happened to my parents up in the midwest and the increased drainage problems from crushed lines led to a basement wall failure. At least you don’t have basements in Florida. ;-)
View William's profile
9949 posts in 2773 days
#10 posted 09-24-2012 01:44 PM
Years ago I moved an 8×10 shed easily.
I brought home eight six inch pipes from work.
Put them under the shed.
Lower the shed onto the pipes.
Get five or six of the strongest guys you know over.
Beforehand, be sure to buy a case of beer or two for “payment”.
It’s cheaper than most ways to move it.
View hairy's profile
2624 posts in 3463 days
#11 posted 09-24-2012 02:01 PM
I’d make sure it’s worth moving before putting any money out. If it’s been there awhile, the bottom could be bad.
-- My reality check bounced...
View Surfside's profile
3389 posts in 2104 days
#12 posted 09-24-2012 02:01 PM
I like William’s suggestion. That’s way a lot cheaper than other options. Plus, you can join the fun! lol
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
Joe Lyddon
#13 posted 09-24-2012 04:54 PM
William has The Plan!
One more thing to be concerned about…
Does the shed have a built-in floor? If so, the large pipe rolling approach, rolling the pipes directly on the ground would work.
If it doesn’t, then the Laying of the wooden rails would probably make it easier to do.
Is the ground somewhat straight (not bumpy)... if not, using the rails would probably make it easier.
If the ground is very soft where the pipes cannot roll freely, the rails would also help.
-- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: ... My Small Gallery:"
View Bill White's profile
Bill White
4875 posts in 3891 days
#14 posted 09-24-2012 04:59 PM
How about 1 pound of plastic explosive? :)
Just couldn’t resist…........
View Milo's profile
#15 posted 09-24-2012 11:14 PM
I think I now have a project for the high school boys youth group at church….. ;)
4WD, wench, pipes, strong young’uns.
Thanks guys!
