BLO, Stain and Polly
Forum topic by Grumpymike posted 09-22-2012 11:28 PM 2255 views 0 times favorited 21 replies Add to Favorites Watch
View Grumpymike's profile
Grumpymike
2238 posts in 2315 days
09-22-2012 11:28 PM
Topic tags/keywords: oak finishing
I have an oak craftsman style table and I want the QS legs and unusual curly grain top to really pop. I have seen that alot of guys use BLO with great results, however we need to stain this piece to match other furniture color.
Do we stain then add BLO and finish with poly?? Or use the linseed oil, stain and polly?? or can you even use them ontop of each other like that??
-- Grumpy old guy, and lookin' good Doin' it. ... Surprise Az.
21 replies so far
View chrisstef's profile
chrisstef
17386 posts in 3006 days
#1 posted 09-22-2012 11:31 PM
I think an oil based stain would work the best. General Finshes is some very solid stuff. I dont have any experience with dyes or stain over blo so cant comment on that angle.
16274 posts in 4218 days
#2 posted 09-22-2012 11:48 PM
+1 on what Chris said.
View Clint Searl's profile
Clint Searl
1533 posts in 2361 days
#3 posted 09-23-2012 12:34 AM
Throw away the BLO; it’s only good for starting fires. Just stain and top with either oil or waterborne poly.
View paratrooper34's profile
paratrooper34
915 posts in 2952 days
#4 posted 09-23-2012 01:37 AM
Mike, personally I cannot stand using any kind of stain on a project. Stains, in my opinion, change the natural color of the wood too much for my taste. I prefer to use oil finishes BLO, tung oil, etc and then once they dry, I use a paste wax such as Johnson’s. I really like the natural color of woods that I use on my projects and have no desire to color them artificially. If I had the piece that you describe above, that is exactly how I would finish it.
-- Mike
#5 posted 09-23-2012 01:42 AM
Well there you go, Mike. It’s unanimous. LOL!
View Fuzzy's profile
Fuzzy
298 posts in 3988 days
#6 posted 09-23-2012 03:32 PM
Clint … you are dead wrong on this … BLO is great for wheelbarrow/shovel/axe handles … other than that, I totally agree … the stuff is way more trouble than it is worth. There are way too many sane, predictable modern methods to coloring/enhancing wood to bother with that old crap my grandfather used, only to find out that it is a crapshoot … one time it looks OK … the next time .. YUCK !!
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
Grumpymike
#7 posted 09-23-2012 06:03 PM
I agree with you guys that stain is not for beautiful wood … HOWEVER … you missed the point.
I have to match her other furniture color. In other words, this lady has a whole room full of matching furniture, and to add this table I gotta match it … all the other (production) stuff has a stain on it; I can match that. (it looks almost like ammonia fumed but it is a stain.)
I like the way that BLO makes the grain pop, then add a water based polly top coat. I have used tung oil with great success … and so on.
I was just asking in which order to apply the three … I think that I will do alot of test pieces and report back on how all this stuff that I should throw away and use for fire starters works out.
I thank you for your comments.
View nwbusa's profile
nwbusa
1021 posts in 2286 days
#8 posted 09-23-2012 06:05 PM
The only time I’d use BLO to start a fire is if I was burning a trash can full of stains. :)
-- John, BC, Canada
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3158 days
#9 posted 09-23-2012 06:53 PM
Double post.
-- jay, www.allaboutastro.com
Cosmicsniper
#10 posted 09-23-2012 06:54 PM
I have never had success at matching another color with stain alone. Even if you knew all the pieces used the same stain, different woods and even different batches can cause a color disparity.
Dyes mixed in alcohol or water is a much better choice in that regard…sprayed on.
Oils enhance the natural contrast in the wood. You can achieve part of that same look with an oil based stain.
I would go that route, getting the color close with it, then fine tune the color with dye mixed with dewaxed shellac. Follows with a film finish of choice.
BTW, such a dyed mix is referred to an a “toner,” because it tones the wood to the desired shade.
Cosmicsniper
#11 posted 09-23-2012 07:03 PM
BTW, if you insist on BLO, I would do that first, follow by a shellac sealcoat, then the stain. I think that will allow the stain to do a better job of toning the without competing directly with the oil. Likewise, stains have pigment, which will block the oil, in part, from doing what you want the oil to do.
View AandCstyle's profile
AandCstyle
3052 posts in 2257 days
#12 posted 09-24-2012 12:05 AM
I agree with Jay. Oil, shellac then stain in that order. Mix the stain a little light, then apply repeatedly until you get the color you want. Be sure to allow the oil enough time to completely dry. HTH
-- Art
Clint Searl
#13 posted 09-24-2012 01:18 AM
You guys with all the oil and shellac sure like to complicate a situation and create multiple opportunities for things to get screwed up. KISS (Keep it simple, Stupid)
Cosmicsniper
#14 posted 09-24-2012 02:23 AM
Matching color is not a simple task. What Grumpymike wants to do is a real life problem without the luxury of second chances. It might mean that he doesn’t get paid.
I too am from the KISS school of thought, but in this case KISS does not apply.
And BTW, oils are one of the best ways to make your projects really pop…I wouldn’t dismiss something like BLO so readily. In Mike’s case, popping the figure first with some BLO is easy. The shellac barrier is then very necessary…and also easy. It’s the third step that it tough…and that’s true no matter what you do beforehand.
nwbusa
#15 posted 09-24-2012 02:25 AM
Clint, I guess we could all just start painting our projects to keep it simple…
-- John, BC, Canada
