| Forum topic by WhoMe | posted 244 days ago | 676 views | 0 times favorited | 13 replies | ![]() |
244 days ago |
i recently comleted a hard maple and cherry wooden mallet and finished it with blo. it is my first attempt at this finish. -- With sufficient thrust, pigs fly just fine. Just watch out for the exhaust. - Mike - |
13 replies so far
#1 posted 244 days ago |
BLO can be a problem once the wood has soaked up its fill of it. It never really dries and hardens, unlike something such as polymerized tung oil, which is what I would use. I find BLO works well with homemade oil/varnish blends, but I hate the stuff straight, especially on lighter woods because I don’t like the yellowish tone it imparts. But in general, I’ve learned to only use enough oil to make the wood pretty, which is usually only a single (or two) application of it…if I need it real hard, I use a blend or top it with some poly. In other words, I don’t trust oil beyond the beauty it provides. I would repair your project by wiping it down really good with mineral spirits. Then, I would attempt to really buff it out…use a little heat (hair dryer) if your buffer doesn’t generate some heat friction of its own. This works pretty well, often well enough to apply a film finish over it. Tough call with a mallet though. You might just need to sand it back…which isn’t too big of deal. Then, apply one thinned coat of the oil followed by film finish, wax, or whatever. I’d be inclined use wax after the oil. If I had a dime for every time I had to resand something, well… The moral to the story…oil doesn’t provide any further benefit once the piece has had its fill, and even then, those benefits are somewhat minimal, unless moisture is a concern. -- jay, www.allaboutastro.com |
#2 posted 244 days ago |
I don’t know how wrong it is, but I always use blo straight. After the first coat ( I do it just like you did) I add additional coats by putting it on and buffing it out almost dry. To fix yours, put a coat of straight blo on with fine steel wool and immediately buff it out as dry as you can. Let it dry for a couple of days then add additional coats as you like. The advantage to thinning on the first coats is dry time is quicker, and its ok but leaving blo to heavy will always turn out gooey. -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#3 posted 244 days ago |
oh wierd I just made one myself and added BLO but I only put on one thick coat and let it seep in for about an hour then buffed it off and then added to coats of paste wax and buffed that out. worked pretty good, but seriously I only put it on for appearance sake, because I am going to abuse the crap out of it! LOL. -- Steve - Wasilla, Alaska |
#4 posted 244 days ago |
Buts that’s the correct way to use it, guys. Apply, wipe off excess, buff out, enjoy. Oil isn’t like poly, where you just keep applying coats to build up a finish. It’s just oil, hardly different from the stuff that used to puddle underneath my old Ford Mustang. I needed kitty litter to sop that stuff up…it wasn’t going away on its own. @Don -In your case, you are applying a light coats a little at a time to slowly get the wood saturated. Its a cautious approach. I think the end result is the same. I’d just use more oil, let it soak for a while, and then wipe off the excess. You just have to let it dry a longer. But whether you let it dry after several small applications or one big application, I’ve found that the time factor is the same. @WhoMe – It’s a common problem that’s happened to everybody. Part of the learning thing. There’s not a standard way of applying every product we use…it comes with practice. For oil, there’s really no benefit to letting it pool on the wood. Just wash it down with a lot of mineral spirits. The soaked in oil will still be there, so there’s not much of an issue with repairing it…just wipe it down and buff it back out. -- jay, www.allaboutastro.com |
#5 posted 243 days ago |
As Jay said, the idea with BLO is not to try to build up a finish with it. It’s just an oil that, IMO, enhances the appearance of most woods. I always use it straight. I slop it on heavy, and almost right away wipe off as much as I can with a rag. I find this has an immediate beautifying effect, and in about 24 hours the piece is ready for whatever other finish I care to put on. Depending on the piece and what kind of use it will get, that could mean just buffing, or paste wax, or poly. -- Charlie M. "Woodworking - patience = firewood" |
#6 posted 243 days ago |
Linseed oil had another major use in the past as an additive to paint to make it flow better. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#7 posted 243 days ago |
+1 to what Charles wrote. That’s exactly how I use it. -- John, BC, Canada |
#8 posted 243 days ago |
you can apply the first time with 50/50 minaral spirit and BLO or LO Dennis |
#9 posted 243 days ago |
Scrub it with naptha to get rid of as much BLO as you can. Then if you want an oil finish use real tung oil. BLO is only good for starting fires. -- Clint Searl.............We deserve what we tolerate |
#10 posted 243 days ago |
Thanks guys. I had only planned on putting a total of 3 coats to treat the wood well. I guess I should have stopped at two. The reason I used BLO was that I already had it here. I never thought of the Tung oil. Oh well, I will try a coupe of the recommendations here and see how it goes. AKSteve, Yes, I am going to beat the heck out of mine too, mainly on chisels and some assembly of projects. But it sure looks nice right now. -- With sufficient thrust, pigs fly just fine. Just watch out for the exhaust. - Mike - |
#11 posted 243 days ago |
I see you’re in California – how humid is it? That will hinder drying if the humidity is too high. Otherwise the solvents in clear paste wax will help take away that stickiness and after buffing it will feel wonderful in your hand. |
#12 posted 242 days ago |
Well, I kind of took the naptha/mineral spirits idea and ran with it. -- With sufficient thrust, pigs fly just fine. Just watch out for the exhaust. - Mike - |
#13 posted 241 days ago |
wax is a top coat you have to reneiw from time to time when you want to try new finishes or experinment with finish ideas then use shop projects can be a great way of try new things on too but you can Dennis |
| Forum | Topics |
Woodworking Skill Share
8797 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1534 |
3553 |
15803 |
Hand Tools
2038 |
Jigs & Fixtures
496 |
Wood & Lumber
2844 |
809 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6163 |
