| Forum topic by WhoMe | posted 238 days ago | 1117 views | 0 times favorited | 35 replies | ![]() |
238 days ago |
i recently bought a rigird 13”planer and even though i have read the instructions cover to cover, i am nervous about turning it on. i know that i should feel more comfortable after i go back and read them again as i unpack and assemble the planer BUT i just know there are things i could cehk before turning on the power. thanks for any help -- With sufficient thrust, pigs fly just fine. Just watch out for the exhaust. - Mike - |
35 replies so far
#1 posted 238 days ago |
seriously? |
#2 posted 238 days ago |
i always stand to the side just in case ready to turn off the switch -- david - only thru kindness can this world be whole . If we don't succeed we run the risk of failure. Dan Quayle |
#3 posted 238 days ago |
As Patron said, also remove valuable breakable items from the potential trajectory path. Lol. Also remember that the full warranty is in effect. Go for it!!! -- Randy-- I may not be good...but I am slow! |
#4 posted 238 days ago |
Don’t sweat it, brother. Raise the planer where the board will slide completely through. Ease it down until you feel the slightest resistance. When you flip the switch, it’s going to be LOUD. Don’t be startled while you hold the board. If you have dust collection, have it running before you flip the switch. Make sure the outfeed is well supported, as you don’t want it tipping into the cutter head. -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#5 posted 238 days ago |
If you might be afraid of the initial noise or fear of unwanted flying objects , use an extension cord to plug it in from a safe distance . Of course you would turn the power switch on before plugging it in to the extension cord while hiding behind a sheet of 3/4” plywood…just in case : ) -- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did. |
#6 posted 238 days ago |
Be afraid…...very afraid. I usually summon the fire department every time I fire-up one of my machines. You know, just in case. Since I lose an appendage every 3rd or 4th time I use my planer, its good to have a medic close by who can quickly sew it back on. LOL. Just jokin ya.In all seriousness its good to be weary when using an unfamiliar machine. Most accidents are products of complacentcy. As Bertha said, the powered planer is the woodworking version of instant gratfication. It can take a piece of pallet wood, and turn it into a thing of beauty. If it wasnt so damn loud, it’d probably be my favorite tool. |
#7 posted 238 days ago |
^awesome, fellas:). ‘sucker’s loud, Ted. It’s like when my compressor fires up out of nowhere and I feel like someone goosed me:) -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#8 posted 238 days ago |
As long as you have checked everything written in the instructional manuals for any power tool, you have done a complete checklist,, no need to add any thing more, they know how to write the manuals for the proper operation of there products, therefor, any time you start up a new machine, knowing you followed all instructions given, proceed as follows. 1. Unplug the machine, |
#9 posted 238 days ago |
Like Al said, wear hearing protection. The planer is the only machine in my shop I actually do this for. -- Charlie M. "Woodworking - patience = firewood" |
#10 posted 238 days ago |
There should be nothing at all to fear if your gonna put wood through it take light cuts at first always stand to the side like Patron said and make shure there’s a lot of space to put the wood through and take out also hook up some sort of dust collection or u will be sweeping up a big mess another safe way to run it is have a person who knows about tha machine show u how to run it ! -- Ike, Big Daddies Woodshop, http://www.icombadaniels@yahoo.com |
#11 posted 238 days ago |
I feel your pain! I remember when I first cranked up mine. Two really important items to check for and do. number one Make sure the exhaust is on Tight because there is a safety cut off switch that it holds down and if it’s not on tight it will stop the planer and it’s a loud screech! yuck. and Secondly although you may not need it yet wax the bottom where the wood feeds in and out because it will eventual stick causing some concern. Also I find that the exhaust will get clogged from time to time causing the chips to fly out the front. No need to worry just clean her out and crank her up again. Good luck and have fun! -- Steve - Wasilla, Alaska |
#12 posted 238 days ago |
Just be cautious and respect the planer but do not fear it. I always raise my planer blades higher than the thickness of the wood to where it does not even plane the board on the first pass…it just goes through. Then I lower it ever so slightly until it skims the board and then gradually lower it from there on additional passes. I am never in too much of a hurry to be careful…and after 64 years I still have all my fingers and toes. -- Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. http://www.FineArtBoxes.com |
#13 posted 238 days ago |
Don’t do anything if it makes you uncomfortable. Incidentally, anyone who gives anybody grief for being nervous while using a new power too for the first time….probably has no business using power tools themselves. now the fact Try approaching it in baby steps. Start it, stand back, and let it run for a bit. That way you know nothings gonna fly off and hit you. Just get use to the noise. Then edge your first piece…make it a pine 2×6 or 1×6….something soft that keeps your hands far enough away to feel comfortable. Do 10 or so passes. Then try face joining the pine….10 passes or so should do it After that you should have all the confidence you need. To be extra sure, go through the safety instructions like a checklist the first 5 times you use it. -- Isaac- Decatur, GA - "Your woodworking....NOT machining parts for NASA!!!" |
#14 posted 238 days ago |
It is times like these everyone should have a ex-wife…... They do come in handy ;-)..... But serious note, After putting together a new machine and starting it up for the first time we all have a little anxiety. With it unplugged, turn your cutter head by moving the belt of course several times and make sure you do not have some left-over parts, plug it in, stay to the side and turn it on. It’s good to be cautious. -- What we do in life will Echo through Eternity........ |
#15 posted 238 days ago |
IsaacH, The OP is operating a planer , not a jointer as your directions seem to imply : ) -- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did. |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3541 |
15750 |
Hand Tools
2028 |
Jigs & Fixtures
494 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
