Forum topic by JesseTutt | posted 09-21-2012 06:59 PM | 2268 views | 0 times favorited | 5 replies | ![]() |
Topic tags/keywords: question metric bolts adjustable handle knob There is a slight mis-alignment in the upper guide assembly on my Grizzly bandsaw. Unfortunately, Grizzly uses metric. Instead of trying to find and use an allen wench every time I raise or lower the upper guide to reposition the side bearings, I am considering replacing the allen cap screws with an adjustable handle knob (picture below). Where can I find a supplier of these? -- Jesse, Saint Louis, Missouri |
5 replies so far
#1 posted 09-21-2012 07:18 PM |
Look here on McMaster-Carr. On the left you can select the metric thread size you need. -- Rex |
#2 posted 09-21-2012 07:19 PM |
Another source is Reid supply. |
#3 posted 09-21-2012 07:27 PM |
Yet another source; |
#4 posted 09-22-2012 12:58 AM |
I second McMaster-Carr. The nut-gripping part on one of these on the tool rest on my cheap Harbor Freight lathe wore out really fast, so I replaced all of them at once w/metal ones from McMaster. Granted, it’s just pot metal, but they still beat plastic. -- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln |
#5 posted 09-22-2012 01:46 AM |
I bought mine at WoodCraft. I bought the larger size, cut the thread off, re-tapped to my desired threading and used a piece of “all-thread” to complete these adjustable bolts. This was one of the first upgrades I did for my astronomical telescope mount, in order to eliminate the “Allen screw” syndrome that you mention: (Below) Tool-less RA & DEC Adjusting Clutch Levers and Thumbscrews – I found the adjustable levers at a WoodCraft Store but they only came in either 1/4-20 coarse thread (too small to drill out and re-tap) or 5/16” threads (got these because they allow for re-tapping) so a good friend tapped and drilled the 5/16” bolt heads on the lever to the required 1/4-28 fine thread pitch and added the all-thread. Spacers are required to miss the RA housing and should be 5/8” long but still leaving 1.5” of threaded bolt on the end. -- HorizontalMike -- "Woodpeckers understand..." |
Forum | Topics |
Woodworking Skill Share
12028 |
Woodturning
2106 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4904 |
6694 |
28052 |
CNC Woodworking
211 |
Hand Tools
5407 |
Jigs & Fixtures
1417 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1186 |
Woodworking Trade & Swap
4754 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
