Difference between shoulder plane and rabbeting block plane?
« back to Hand Tools forum
Forum topic by mikecorwin posted 242 days ago 533 views 0 times favorited 7 replies Add to Favorites Watch
View mikecorwin's profile
mikecorwin
12 posts in 720 days
242 days ago
Topic tags/keywords: shoulder plane block plane
What is the difference between a shoulder plane and a rabbeting block plane? Where would you rather use one over the other?
7 replies so far
View crank49's profile
crank49
2286 posts in 1139 days
#1 posted 242 days ago
I have a Stanley SW #92 which is a shoulder plane.
I use it for trimming the shoulders and cheeks of tennons.
I wish I had a rabbiting block for the cheek work because the cutter is wider.
Also, the block looks like a more comfortable plane to hold and work with and it would be useful for more kinds of work.
If I had a rabbiting block, I think the only time I would use the shoulder plane would be where I need the narrow body, like in a dado or something. But, then a router plane would be better for that.
Come to think of it, I don’t know why I bought a shoulder plane other than it was on sale.
Your mileage may vary, but that’s the difference from my point of view.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
View Loren's profile
4882 posts in 1816 days
#2 posted 242 days ago
Mass. Fine shoulder planes have concentrated mass which helps them
make demanding paring cuts on end grain. You can also use them
on their sides referencing off a tenon cheek to cut the shoulder
perfectly square. You can push the plane or flip it over and pull
in towards you, which is not as friendly a method with a skew-blade
plane, assuming you have access on both sides, the acute and
obtuse corners of the iron cut differently in terms of feel and
adjustment.
View bondogaposis's profile
bondogaposis
1244 posts in 520 days
#3 posted 242 days ago
Shoulder planes can clean up dados.
-- Bondo Gaposis
View Don W's profile
Don W
9952 posts in 736 days
#4 posted 242 days ago
Sounds like its been said , but I’ll reiterate. Shoulder plane for shoulders, block for cheeks. Wider blade for wider cut like on the check and lots of side reference and weight for the shoulders
View Cosmicsniper's profile
Cosmicsniper
2148 posts in 1327 days
#5 posted 242 days ago
I use my LN rabbet-block most of the time. But sometimes, a part maybe small enough where I can’t clamp it down (I don’t have a nice workbench for that). Then, I might use the shoulder plane (new Sweetheart #92) because I can do it in my hands (holding it down only with my left hand and trimming with my right). As Loren says, the mass makes a difference.
Don’t know if that makes sense, but it’s kinda a “feel” thing. If I can’t do it with the LN, then I resort to the SW.
-- jay, www.allaboutastro.com
Cosmicsniper
#6 posted 242 days ago
Oh, and I like what Loren said about using the shoulder plane by pulling it towards you…I did that on a box top I made the other day.
And while I’m thinking of it, sometimes the width of the work is too narrow to keep the rabbet-block plane reliably square. That’s a prime job for the 92.
mikecorwin
#7 posted 242 days ago
Thanks everyone! Good advice, never really thought about how it might be hard to balance the rabbeting block plane on a tenon shoulder. Gonna check out both at the Lie Nielsen tool event in my town next week!
