making sense out of metric machine screw (bolts) specifications?
Forum topic by JesseTutt posted 09-21-2012 04:32 PM 3451 views 0 times favorited 8 replies Add to Favorites Watch
View JesseTutt's profile
JesseTutt
854 posts in 2138 days
09-21-2012 04:32 PM
Topic tags/keywords: question machine screw bolt metric
I understand the notation for machine screws used in the United States. A 6-32×1 would be a #6 diameter, 32 threads per inch, and 1” long.
How do I interpretate metric machine screws?
What would “Cap Screw M6-1×20” mean? Another example is “Carriage Bolt M8-1.25×85”.
8 replies so far
View Loren's profile
10476 posts in 3675 days
#1 posted 09-21-2012 04:49 PM
The M number is the diameter of the shank in mm. The middle
number is some sort of pitch designation I think. For an M6 it’s
usually 1 and for M8 it’s higher and for M5 it’s lower. The final
number is the length in mm.
View ChrisK's profile
ChrisK
1973 posts in 3109 days
#2 posted 09-21-2012 04:52 PM
M6 -1×20
M6 – 6 mm dia thread, 1mm thread pitch 20 mm long.
Head styles names are the same as US standard
Check McMaster-Carr’s web site for all of the dimensions for each head style
-- Chris K
JesseTutt
#3 posted 09-21-2012 05:07 PM
does thread pitch map into something simular to threads per inch? Threads per cm?
#4 posted 09-21-2012 05:11 PM
My best guess is it’s the mm length on a complete thread.
Thus m6-1×20 would have 20 threads because the ratio
is 1. M8 is commonly 1.25 so in that case you’d need
a 25mm shank to have 20 threads.
View crank49's profile
crank49
4032 posts in 2998 days
#5 posted 09-21-2012 05:13 PM
In the above example:
M6 – 1 X 20
6mm dia. – 1mm pitch (means one thread per mm) x 20 mm long
View Rex B's profile
Rex B
320 posts in 2278 days
#6 posted 09-21-2012 05:56 PM
crank49 is correct, 1mm thread pitch means that the distance from the peak of one thread to the next peak is 1mm. Likewise the distance from one valley to the next is also 1mm. See here.
-- Rex
JesseTutt
#7 posted 09-21-2012 06:44 PM
Thanks all, that was what I wanted to know
View Bill White's profile
Bill White
4950 posts in 3988 days
#8 posted 09-21-2012 06:46 PM
Want me to REALLY start an issue?
I wish we would all go metric since we have to own multiple tools to achieve the same results. I even had some “Whitworth” stuff from the motorcycle repair days.
Blast away if ya will, and I’m not tryin’ to hijack.
Bill
-- bill@magraphics.us
