Looking for spearpoint marking knife blade.
Forum topic by groy87 posted 09-21-2012 04:52 AM 2101 views 0 times favorited 10 replies Add to Favorites Watch
View groy87's profile
groy87
136 posts in 2895 days
09-21-2012 04:52 AM
Topic tags/keywords: blade marking tool
Hello, I want to make my own dovetail marking knife and I’m looking to use a spearpoint blade similar to the ones supplied by czeck edge and the following examples.
Ebony Marking Knife – by CartersWhittling @ LumberJocks.com ~ woodworking community
http://lumberjocks.com/projects/12619
http://www.inthewoodshop.com/ShopMadeTools/A%20Knife%20for%20Marking%20Dovetails.html
http://lumberjocks.com/projects/55174
http://lumberjocks.com/projects/14267
Normally I would try to make my own following the tutorial but I dont have access to the necessary tools. If someone has a dovetail blade or is willing to make one similar to the examples I would be happy to trade a few blanks or kits for their efforts.
Thanks in advance.
10 replies so far
View BigYin's profile
BigYin
421 posts in 2472 days
#1 posted 09-21-2012 05:26 AM
make one with a 6mm or 8mm flat drill bit.
use a grinder to shape and oilstone to sharpen and flatten the back
dont overheat when grinding
-- ... Never Apologise For Being Right ...
groy87
#2 posted 09-21-2012 05:42 AM
I would normally want to make everything myself but I like i said i don’t own or have access to the necessary tools. :/ that’s why I’m looking to trade :)
View Dan Krager's profile
Dan Krager
4071 posts in 2290 days
#3 posted 09-23-2012 02:58 AM
Groy87,
I’d be happy to grind a few points for you. Do you have material to send? If so, send a couple to start and I’ll point them to your spec. It will be fun for me and no cost to you. I have made my own knife and it resides in my apron pocket like a pencil with a plastic protector over the point.
You can learn about me at:
http://kragerwoodworking.weebly.com/
Mailing address:
Dan Krager
4730 North Wilder Road
Olney IL 62450
-- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com If there's only one hole in the road, your tire will find it.
View Lee Barker's profile
Lee Barker
2170 posts in 2906 days
#4 posted 09-23-2012 01:26 PM
Do you have a hacksaw and a file? Oh, and a vise? You can make your own from meat forks purchased at thrift stores.
There are four at different stages of construction on the right side of this picture:
Kindly,
View TartanSailor's profile
TartanSailor
29 posts in 2309 days
#5 posted 09-25-2012 04:26 PM
I make mine out of old hacksaw blades and bandsaw blades. Work just fine.
-- NJ Sailor
TartanSailor
#6 posted 09-25-2012 04:30 PM
I make mine out of old hacksaw and bandsaw blades. They work just fine.
-- NJ Sailor
View rance's profile
rance
4259 posts in 3216 days
#7 posted 09-26-2012 03:29 AM
A jigsaw blade works for me.
groy87
#8 posted 09-27-2012 04:14 AM
Would any jig saw blade work or is there a partictular size?
rance
#9 posted 09-27-2012 01:12 PM
Just about any decent quality one. The width is more important to get the size marker you are wanting. I like these over a hacksaw blade because they are thicker, which equates to more stiffness.
Of course a used one is better. :)
View paratrooper34's profile
paratrooper34
915 posts in 3007 days
#10 posted 10-01-2012 11:44 PM
Groy, jigsaw blades or sawzall blades make great material for stuff like this. You don’t need much to make a blade. You need something to cut the blade from the donor; gonna need to be a cutoff blade in a Dremel or the like. Or if you have a grinder, just grind it to final shape. Then you remove the paint. I took the paint off blades with a rough stone (250 grit I think). But you can get it off other ways. Once that is done, hone it and polish it, which can all be done with sand paper if that’s all you have. It is very easy work. Good luck!
-- Mike
