Installing my new (2006) felder CF-741 and FB-540 band saw
Forum topic by mbs posted 246 days ago 1667 views 0 times favorited 19 replies Add to Favorites Watch
View mbs's profile
mbs
971 posts in 1112 days
246 days ago
Topic tags/keywords: felder combination machines cf-741 fb-540 bandsaw
There is quite a bit of setup time and learning involved in using one of these european combo machines. I bought it used from an estate so I didn’t get a good review with the owner about some of the accessories that came with the machine. I’m fairly sure many of the items are felder specific.
The felder rep on the west coast (Carl) has been very helpful. I will take my time and work through the details.
I’m still in the process of setting it up but i have made a few cuts with the saw and I’ve used the shaper/jointer. I really enjoy nice equipment and this is truly nice. The setup time is considerable for me since I’m learning. I also bought the fb-540 band saw and the 125 dust collector. I already have a dust collector so I won’t be using it right now.
s
The band saw is also a 2006. it only has one dust collection port but the area under the trunion is sized just about right for a 4” dust collection hose to fit right behind the blade.
-- Sorry the reply is so long. I didn't have time to write a short reply.
19 replies so far
View Joseph Jossem's profile
Joseph Jossem
164 posts in 440 days
#1 posted 246 days ago
that is a awesome set up organized and cleaner then my house. nice view out the shop door I am jealous.
View Loren's profile
4898 posts in 1820 days
#2 posted 246 days ago
I have a Felder table saw. I made my own crosscut support
table out of an aluminum extrusion and saved like $500. I don’t
have the outrigger like you do, but a smaller little cantilevered
outrigger is fine for many boards and doesn’t try to hit you
in the groin too often. I’ll post pictures sometime.
View mbs's profile
mbs
#3 posted 246 days ago
I’d like to see how you made your cross cut support, Loren.
View bigkev's profile
bigkev
196 posts in 800 days
#4 posted 246 days ago
Very nice. Looks new from the pics. Started another chair yet?
-- Kevin, South Carolina
View mbs's profile
mbs
#5 posted 246 days ago
It’s like new. he only made enough dust to fill the bin once then, unfortunately, be became too ill to work in the shop.
I started a chiar for my mom knowing that i would not finish it until around Christmas this year. I got the rockers, back braces, and seat glued up. How ‘bout you?
View RogerM's profile
RogerM
316 posts in 571 days
#6 posted 245 days ago
Must have been one real fine estate sale. Wish I was in Az.
-- Roger M, Aiken, SC
View mbs's profile
mbs
#7 posted 244 days ago
It was in NM. Had to drive 650 miles round trip to get it. I ended up buying it sight unseen but it worked out fine.
View mmlaing's profile
mmlaing
14 posts in 1479 days
#8 posted 244 days ago
I have a CF741 p like yours , have you tried the power planer table yet, it is really a nice feature on the machine. Once you get used to doing all operations at once the combo machine is nice to work with, my favourite part of the machine is the xroll slider. enjoy
Mike
View mbs's profile
mbs
#9 posted 243 days ago
I have tried the planer just to make sure it works and i like it. Do you have the shoe that fits on the end of the slider? it’s used to straight-line rough lumber. I have it but the wood can move quite a bit at the shoe. do you have the same issue?
View whitebeast88's profile
whitebeast88
1878 posts in 362 days
#10 posted 243 days ago
wow!nice set up.enjoy.
-- It don't have to be straight,it's just a suggestion!!!
bigkev
#11 posted 243 days ago
No, not yet. I need to get up to Charlotte or Asheville and buy some walnut. Not easy to find here in central SC. When I go I’m going to pull my trailer and stockpile some. I look forward to seeing yours around Christmas though.
View Surfside's profile
Surfside
2287 posts in 345 days
#12 posted 243 days ago
I agree, it’s a real nice setup you’ve got!
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
mmlaing
#13 posted 242 days ago
yes I have the same problem. I take the clamp for the slider and use it to hold a 2×2 about 10 inches long with 2 1/2 inch drywall screws driven in about every 2 inches. This device does not look as nice but when the end of the wood bites into those screws nothing moves.
Mike
View mbs's profile
mbs
#14 posted 241 days ago
That’s a good idea, Mike.
View Fishinbo's profile
Fishinbo
4345 posts in 348 days
#15 posted 240 days ago
Great machines and equally impressive workplace!
