Cutting a really wide chamfer?
Forum topic by jdmaher posted 272 days ago 1041 views 0 times favorited 36 replies Add to Favorites Watch
View jdmaher's profile
jdmaher
177 posts in 777 days
272 days ago
How to cut a really wide chamfer?
This is for the top of “sideboard” (that will actually be used to store AV electronics). The top is 50” long and 18” wide and 1-1/8” thick. I want to cut a wide chamfer of about 8.5 degrees on three edges. That will leave 3/4” cut edge thickness, and provide a chamfer about 2.5” wide.
For the long dimension, I’ll put a nice high support on the fence, crank in the angle and run it along. Probably do it in at least two passes to “sneak up” on a nice finished cut.
Here’s the problem: in my basement shop, I don’t have the ceiling height to use the same technique for the width edges.
I’m sorta thinking circular saw. I guess I could clamp the board, upright, to the railing on the deck, along with a “box” to provide surface area for the base of the saw. Then do the same thing: set an angle and “sneak up” on the cut.
But that seems like a kludge.
Am I overlooking a nice, safe, easy answer?
-- Jim Maher, Illinois
36 replies so far
View Nick_R's profile
Nick_R
77 posts in 347 days
#1 posted 272 days ago
Sounds like a tough one.. This sounds stupid, but can you lay your router table on its side?
-- Hope for the best but plan for the worst. - 7 finger Nick :)
View Murdock's profile
Murdock
100 posts in 681 days
#2 posted 272 days ago
I had the same problem recently on a buffet table I was helping with. Sadly we ended up taking it to a cabinet shop to have it done. I think we paid them $20 or $30 to do it. We had to call 4 shops before we found one that would even entertain the idea.
Circular saw can work if you have a steady hand even if you are using a strait edge.
-- "Anyone who has never made a mistake has never tried anything new." - Albert Einstein
View crank49's profile
crank49
2378 posts in 1168 days
#3 posted 272 days ago
Nice, safe, easy.
Hand plane.
Piece of cake.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
View Mosquito's profile
Mosquito
2942 posts in 490 days
#4 posted 272 days ago
I use hand planes to do chamfers that size, safe, quiet, less dust.
Otherwise, if you have a router, see if you can find a bit that would work, though the smallest I’ve seen is 11.25 degree… or you could go with a really large bit (such as panel raiser) but those are expensive. And you’d need a variable speed router.
edit: Michael beat me to it on the hand plane
-- Mos - Twin Cities, MN -- Stanley #45 Evangelist - www.youtube.com/MosquitoMods
jdmaher
#5 posted 272 days ago
Handplane, huh?
You know, I got me some of them, but I almost never use them. My hand skills – well, let’s see, what’s the word?, oh yeah! – SUCK!!!
Actually, my hand skills are pretty non-existent. It always seems easier to set up a machine, and there’e that illusion of precision. Plus, I fear making a mess of really nice figured cherry. Still, that’s probably the right thing to do . . .
I did think about a panel-raising bit on the router table set up with an outrigger, but for two cuts, that seems excessive.
Maybe its time to try hand-planing . . .
Smitty_Cabinetshop
6592 posts in 816 days
#6 posted 272 days ago
Handplane. Use a marking gauge to mark your lines on top and edge, and go to town. Easy, safe and deliberate…
EDIT: Oh, and precision? No equal to a smoothing plane that can take a thou here and there…
-- Don't anthropomorphize your handplanes. They hate it when you do that. -- OldTools Archive
View Loren's profile
5031 posts in 1845 days
#7 posted 272 days ago
Snap some chalk lines, hack off most of the material with a drawknife,
move to a hand plane or a shinto saw-rasp, then to finer files, then
sand with a block.
View Mainiac Matt 's profile
Mainiac Matt
1780 posts in 526 days
#8 posted 272 days ago
You might be able to pull this off with a raised panel bit on a router table
-- Pine is fine, but Oak's no joke!
View Cosmicsniper's profile
Cosmicsniper
2155 posts in 1356 days
#9 posted 272 days ago
Quick and easy with a hand plane…hog off most of the material like Loren said, though I’d use the circ saw for that.
-- jay, www.allaboutastro.com
View Gshepherd's profile
Gshepherd
1363 posts in 399 days
#10 posted 272 days ago
Do you have a sliding miter saw?Cut Flip to do the other side. Of course you will have to sneak up on the second cut but you can be surprised how close you will get it.
-- What we do in life will Echo through Eternity........
View Wdwerker's profile
Wdwerker
313 posts in 431 days
#11 posted 272 days ago
Make a jig and use a router. Rip some large angled wedges to put under a jig. A hinge mortise bit or something that will leave a flat bottom cut. Then sand untill it matches the front bevel.
-- Fine Custom Woodwork since 1978
bandit571
3841 posts in 881 days
#12 posted 272 days ago
Start out at the edge, where you want the champfer to go. Angle a handplane so that it cuts at a diagonal to the direction you will be going. Also lay the plane at the angle of the champfer. First pass will just take off a thin ribbon. Next pass, the ribbon gets a bit wider. And so on until the champfer is finished, in maybe 10 minute per.
Go to my project gallery. Look up a “TV Table’ , made from red wood, cedar I think it was. All the edges were done this way. With a simple #3 smooth plane.
Note: when doing this, make sure the front”knob” is hanging over the edge. You want to go along at angle.
View casual1carpenter's profile (online now)
casual1carpenter
262 posts in 673 days
#13 posted 272 days ago
mount the circular saw to a table / workbench set angle so as to rotate the circular saw not the table top. or mount the saw base 90 degrees to table dial in angle with saw tilt.
View 1yeldud1's profile
1yeldud1
235 posts in 1239 days
#14 posted 272 days ago
any chance you could just roll your table saw outside and find a way to support the work piece upright while making these 2 cuts ?
View cabmaker's profile
cabmaker
1050 posts in 1006 days
#15 posted 272 days ago
You could have it done in the time it takes to read all these responses. (with #6 or #7), plane that is.
showing 1 through 15 of 36 replies
