Bent wood jig
Forum topic by RussellAP posted 09-19-2012 08:53 PM 5354 views 0 times favorited 9 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3104 posts in 2282 days
09-19-2012 08:53 PM
Made a jig that will bend me a couple of curves. I may build another with one sweeping curve or just wait till I design something and build the jig to fit.
Here’s the jig.
This was Cedar 5/4 cut to 4 1/8 strips and glued and set in the mold.
You can’t see the seems, and it’s strong as heck.
9 replies so far
View Loren's profile
10379 posts in 3643 days
#1 posted 09-19-2012 09:35 PM
That’s nice.
View levan's profile
levan
472 posts in 2975 days
#2 posted 09-19-2012 11:22 PM
looking good!! Your into the fun stuff now.
-- "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford
View Lee Barker's profile
Lee Barker
2170 posts in 2846 days
#3 posted 09-19-2012 11:31 PM
What adhesive, and how long in the clamps?
Kindly,
View Gshepherd's profile
Gshepherd
1727 posts in 2197 days
#4 posted 09-19-2012 11:52 PM
Works good. If your going to do a lot of different curves I would suggest getting some 1/4 steel brackets (L) and drill a few hold in one of the legs, draw out your curve, about every 3-4-5 inches screw them down in line with the curve, get some 1/16 steel banding and that will go against the L brakets followed by your wood strips the another band and some clamps. Let it sit for 24 hrs. Beware of some spring back in come cases. Width depends a lot on the curve and wood itself. I usually just cut a strip and bend it to see where the breaking point is. More times than not 1/8 works pretty good. I had a local welding shop bend the L brackets to make sure they were all perfect and they had the steel needed at a decent price. Doing curved work is enjoyable to do. I use Titebond II Extend…..
-- What we do in life will Echo through Eternity........
View okwoodshop's profile
okwoodshop
448 posts in 3170 days
#5 posted 09-20-2012 01:32 AM
What kind of project are you using these on? I use a similar jig to make laminated rockers for my chairs,and another for the back slats.But this is a more unique bend.Looks real good.
RussellAP
#6 posted 09-20-2012 03:44 AM
Lee. Titebond II and I left it about 3 hours.
RussellAP
#7 posted 09-20-2012 03:47 AM
Okwoodshop- I plan to make a few more jigs for some custom stuff for tables and other things. The next jig will be made for some table legs for some deck furniture.
#8 posted 09-20-2012 03:51 AM
I bent some wood last month by sawing it to 1/10” thick and
bending 2 sections on a hot pipe by hand. Once those were
laminated together the additional sections didn’t really need
the hot pipe as the form was more or less set by the
glue line in the first 2 parts. Not very neat, because
gaps happen, but a handy way to rough out bent laminated
forms for prototyping, painting or whatever and skipping
the construction of a 2-part form.
okwoodshop
#9 posted 09-21-2012 03:10 AM
looking forward to seeing the projects
