| Forum topic by alekhine | posted 247 days ago | 1025 views | 0 times favorited | 23 replies | ![]() |
247 days ago |
Topic tags/keywords: question cherry carving tool rustic wormy beetle
I have eight cherry boards that are seriously damaged by wood beetles as you can see in the pictures. They are approximately 75cm x 27cm x 3cm (30” x 11” x 5/4”), air dried for a long time. The one in the middle is that i cleaned the holes with power carving tool. It took 3 hours to clean the holes in just one board so i started to think to myself is it worth this effort. I will appreciate if you give your opinions for any of my questions: 1- What project would you build with these boards? -- Efe Yaparoglu ,Izmir.... Not getting what u wished is a sign that there is something better behind. |
23 replies so far
#1 posted 247 days ago |
Are they still infested? The board on your left at the top is that a worm still chowing down? I would not let any of it around my stash of good lumber. Looks like birdhouse lumber to me or something that you would make for outisde. As is it goes for weather it is worth the time or not that all depends upon you. I would not waste a lot of time myself on the holes except for some spar varnish…... You are already woundering what you are doing when you start questioning yourself. It would make for some good birhouse material and hey it comes with a free lunch for the new tenents…..... -- What we do in life will Echo through Eternity........ |
#2 posted 247 days ago |
Clean out the holes the best you can with a dental pick, cut them in half and put them in the oven on the lowest setting you can. Mine goes down to 170°F. Let them bake for a coupe of hours. That will kill all the bugs that are living. -- Improvise.... Adapt...... Overcome! |
#3 posted 247 days ago |
Well, there’s wormy wood…and then there’s this stuff. I would maybe consider filling one with a thick glaze coat like Famo or something like that for an interesting side table top, but in reality, I could not use it. And the possibility of living insects in there would be enough for me to chuck it. -- Paul, Tennessee, http://www.tsunamiguitars.com |
#4 posted 247 days ago |
I agree with Dallas and Tennessee. Hmm, two cities. Well I’m from Detroit, so now it’s three. Anyway, clean up the lumber as best you can, stick the boards in the oven to kill the bugs, put some colored epoxy in the holes and use them for a table top. I think that would look pretty cool, especially when the cherry ages. |
#5 posted 246 days ago |
You can’t throw them away – wood with character! Your nick, by the way, honours the Grandmaster? (Who, coincidentally, died here in Portugal) -- "Do not speak – unless it improves on silence." |
#6 posted 246 days ago |
I have the same problem. Kept outside in its own pile—I think the ants go after them. In cherry I find it difficult to clean the holes. Pressure washer then microwave works good. I read the only sure way is high temperature. I’ll stick with wormy chestnut, wormy butternut, spalted silver maple for my “rustic” material. Cha Cha Cha -- Steve, 'Sconie Great White North |
#7 posted 246 days ago |
leave them rough ,put some satin spar urethane on them and they are about the right size to make a couple fishing rod racks out of.Maybe stain one darker |
#8 posted 246 days ago |
Look at my “Arkansas Cherry Table” to see what I did with some cherry that was in much worse shape than yours. My best friend has it in his log home and he and his wife love it. I would love to have that cherry and would make a dresser top valet from it. I used an air gun and dental pick to clean all the castings out of the holes and tunnels. -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
#9 posted 246 days ago |
Do not burn them Sadly they are yours and not mine. In the right hands, its worth as much as gold by weight. -- "Good artists borrow, great artists steal”…..Picasso |
#10 posted 246 days ago |
I agree with “Moron”. I made my daughter a jewelry rack here and I have more projects in mind with the left over. Don’t go cutting it up and throwing it in the oven until your sure you have something living in it. I spent five minutes cleaning up the board you see in my project…................... -- mike............... |
#11 posted 246 days ago |
Gshepherd, that is not a worm you ask in that picture:) But i am not 100 percent sure there is no beetle inside, i hope not.. KnickNack, some of the holes that go through to the other side and openings in both sides are 5 mm in diameter (quite big).. And my nick you ask, yes! he was the grandmaster, one of the world champions and my favourite because of the character in his play. Last day of his life was in Estoril as you said. Thanks you all for the comments you give, -- Efe Yaparoglu ,Izmir.... Not getting what u wished is a sign that there is something better behind. |
#12 posted 246 days ago |
Looks a little like carpenter bee damage. If it is beetles, the kind that make those sized holes do not persist in dry wood. It is definitely not the dreaded powderpost beetles. I suspect that the party is over and the bugs are gone. -- Wood-Mizer LT15 |
#13 posted 246 days ago |
I have heard that you can stick the boards in the freezer for a few days/weeks and that’ll kill the bugs, but I have no reliable reference to back that statement up, so take it for what it’s worth. -- -=Pride is not a sin=- |
#14 posted 246 days ago |
”Clean out the holes the best you can with a dental pick, cut them in half and put them in the oven on the lowest setting you can. Mine goes down to 170°F. Let them bake for a coupe of hours. That will kill all the bugs that are living.” sorry, but I could NOT bring myself to put something in the oven to kill worms, then use that oven to cook food. It would mess with my mind too much. “Is it just me or does this pizza taste a little…..wormy?” |
#15 posted 245 days ago |
Jerkylips, I have a question: Why would it bother you? I suppose you didn’t know that federal standards for pure flour include, “No more than 30 insect parts per pound”. Have a Great wood working day! -- Improvise.... Adapt...... Overcome! |
| Forum | Topics |
Woodworking Skill Share
8797 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1535 |
3553 |
15803 |
Hand Tools
2038 |
Jigs & Fixtures
496 |
Wood & Lumber
2844 |
809 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6163 |
