| Forum topic by Clint Searl | posted 246 days ago | 295 views | 0 times favorited | 4 replies | ![]() |
246 days ago |
I’m going to lay a 3/4×5 T&G Heart Pine floor on a radiant slab, and want to glue it directly rather than over an underlayment and/or floating. The slab is dry as a bone and the ambient humidity never exceeds 35% (NM). I would appreciate hearing about any similar experience. TIA -- Clint Searl.............We deserve what we tolerate |
#1 posted 246 days ago |
I glued down a bamboo when I moved into my house 2 years ago. I learned alot about slab moisture due to bamboos reaction to any humidity. What I learned is its not the ambient humidity but rather humidity coming from the ground underneathe the slab. Im assuming it dose rain atleast occasionally in NM. Its hard to get a slab perfectly moisture proofed. Water from the ground around the slab can migrate under the slabs edges. I had to use a special urethane based glue that created a waterproofing layer. It was kind of pricey and very stiff to spread. I had a hard time walking the next day after gluing 500 sqft. -- Isaac- Decatur, GA - "Your woodworking....NOT machining parts for NASA!!!" |
#2 posted 246 days ago |
Isaac, thanks for the info. I’m sure the slab won’t be wicking any moisture, and I plan to use a urethane adhesive. My main concern is if there are any issues associated with gluing it to a radiant floor. -- Clint Searl.............We deserve what we tolerate |
#3 posted 246 days ago |
depends on how the floor is done if the tubing is buried in a concrete slab then I would not recommend using solid flooring period. Most use an engineered flooring as it wont buckle and warp. Thats a no no in my books -- "Good artists borrow, great artists steal”…..Picasso |
#4 posted 244 days ago |
Moron, the previous owner installed the same pine flooring in another room at least five years ago, and the radiant heat in the slab has not been an issue. The boards have not buckled, cupped, or warped. I don’t know if it’s glued or floating. -- Clint Searl.............We deserve what we tolerate |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1534 |
3550 |
15785 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6159 |
