Bent wood world
Forum topic by RussellAP posted 244 days ago 818 views 0 times favorited 2 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
2394 posts in 454 days
244 days ago
After watching my Facebook friend Woodworking or mere mortals make a jig for bending thin strips of wood, I had to try and make one.
I took a sheet of 5/8 plywood and cut it into 16 inch by 4 foot pieces, then screwed them together and put a template of a couple curves on it. Woodworking or mere mortals has a link to the template.
The thickness of my plywood made cutting curves in it nearly impossible. I used 4 ply’s and I don’t think my BS can take much more of this.
I’m going to make another out of a second sheet of plywood, maybe two different curves, or just a jig to make certain angles.
The options are to cut the strips to be bent very thin, then you can either soak them, or glue them up and bend 4 or 5 at the same time.
I have some small strips from a 2×4 in there now drying, they should retain the curve when I take them out.
This is the jig Woodworking or mere mortals made.
-- Failure does not stop me, it makes me try harder..... because I'm crazy.
2 replies so far
View Jacob's profile
Jacob
73 posts in 809 days
#1 posted 230 days ago
This sounds like a good time for some pattern routing before you laminate your plywood together to make the mold. It would take the stress off of your band saw and probably make a more consistent mold. Are you just experimenting or are this shapes intended for something.
Bent lamination is awesome! its also super economical for lots of shapes you would ordinarily cut from solids. Also, if you play with contrasting woods you can make some very interesting edge treatments. I’ve had friends even laminate colored paper between the layers in less structural applications
-- -Jacob Turetsky, Industrial Designer (student), www.Coroflot.com/Jturetsky
4874 posts in 1815 days
#2 posted 230 days ago
You can put fabric softener in the soak water and the wood
gets more pliable… an interesting technique to play with and
suitable for some sorts of things.
