I need a smoothing rasp with a flat side that has non-cross-hatched teeth, approximately 15 to 20 per inch. I found one years ago that's worn out that says "Made in USA" but no other inscription. It is 3/4ths in wide and 8 inches long. I use it for smoothing very hard bois d'arc (osage orange) wood for bows and arrows. Have checked Nicholson but they don't make such. Must be non-cross-hatched!!
Look at Iwasaki files. Even the coarser ones deliver a finer cut
than most rasps and there are some very fine models available.
I think if you try one you will love it.
In terms of the specialized file you prefer, it may be for a
specific trade like jewelry or cutting bone. Nicholson
used to make a lot of models they don't make anymore.
Depending on your task, I would think you could adapt either plane maker's floats or a flat needle rasp to your job. If you're doing coarser work or large curves, I would think the Auriou rasps (and others) could be adapted to your job.
Hope this helps.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
