| Forum topic by jacob34 | posted 248 days ago | 392 views | 0 times favorited | 8 replies | ![]() |
248 days ago |
Fellow Lumberjocks I have a question, I have a liquor cabinet I am building which is the first furniture piece I have started in which well honestly I am truly focused on all parts on my project being square and true. My problem is that I need to square up board that are 12” wide and 40” long, my usual method is to use a shooting board but with the shop I have and work space I am looking for other methods for the larger boards. Any suggestions? I have a miter saw but it is not a sliding saw and will fit a board that large. -- two men walk into a bar the third one ducks, which are you?? |
8 replies so far
#1 posted 248 days ago |
How about a straight edge and router method? -- What we do in life will Echo through Eternity........ |
#2 posted 248 days ago |
Updated: Using my 12” MS I have successfully flipped the board to get a complete cut. Sometimes with batter precision than others. When I do this I take the time to set the 90 using a large square in BOTH dimensions FIRST. Yes, it takes practice but it can be done. Before: -- HorizontalMike -- "Woodpeckers understand..." |
#3 posted 248 days ago |
you could use a square as a guide for a skill saw. If you don’t think you can hold the square solid enough, clamp it. The other option is a square with a hand saw. I’m more accurate with option one, but you may be different. -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#4 posted 248 days ago |
I don’t have a router, I know should have been a early purchase, I did wonder about just a straight edge and circular saw with clean up with a block plane. Horizontal my table saw is not square I have been messing with it since I got is and so my sled is not the route I want to do on the project. -- two men walk into a bar the third one ducks, which are you?? |
#5 posted 248 days ago |
I kinda thought I would go some route with a straight edge or square. I like the idea of a skill saw thanks Don -- two men walk into a bar the third one ducks, which are you?? |
#6 posted 248 days ago |
The way Don explains it is how i cross cut all the large board in my shop. I hold the framing square againt the board and let the edge of my circular saw run against it. Quick n easy. -- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty |
#7 posted 248 days ago |
I got this from HF to use with my circular saw and it works as good as the Bora clamps like it that I have used.
50” Clamp and Cut Edge Guide Pittsburgh – item#66581 Purchase In Store Only
If your toatly against HF Tools Sears sells the set of Bora clamps in the same style. |
#8 posted 248 days ago |
HF has a better warranty and return policy than Sears. |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3552 |
15797 |
Hand Tools
2038 |
Jigs & Fixtures
495 |
Wood & Lumber
2842 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
