Kreg K4 Master Jig Question
Forum topic by BentheViking posted 09-17-2012 01:08 PM 1353 views 0 times favorited 5 replies Add to Favorites Watch
View BentheViking's profile
BentheViking
1782 posts in 2467 days
09-17-2012 01:08 PM
Topic tags/keywords: jig question aspen drill-driver joining face frame cabinets
So I finally got a chance to use this over the weekend and I had forgotten how great of a kit this is.
I was converting a kitchen cabinet to a spot for the microwave so I was basically building a face frame to inset within the original cabinet frame. I was using 3/4” Aspen and the original frame was also 3/4”. I had a few spots where I don’t know quite what happened but the screw went just a little too much and started to splitting the wood on the front side. I’m not sure if the wood was slightly less than 3/4” in that one spot, if the screws were a little long (1 1/2”), if my angle on the screw insertion was a little off from the pilot hole, or if I just drove the screws a little too deep into the soft wood.
My question is have you ever (just to be on the safe side) used the wrong sized set up on this jig? ie I would have used the 5/8” set up rather than the 3/4” or if you were working with a something that was 1 1/8” thick using the 1” spacing.
-- It's made of wood. Real sturdy.--Chubbs Peterson
5 replies so far
View Lifesaver2000's profile
Lifesaver2000
551 posts in 3015 days
#1 posted 09-17-2012 10:18 PM
I believe the recommended screw length for 3/4 to 3/4 joints is 1-1/4 inch, not the 1-1/2 inch you said you were using. This could be the source of your problem.
View JarodMorris's profile
JarodMorris
167 posts in 2278 days
#2 posted 09-17-2012 10:44 PM
I echo Lifesaver2000. I think the manual says 3/4” wood = 1 1/4” screws. Hope you can get the split fixed. Glue and press back into place? If you try to press, make sure you put waxed paper on your clamp or you’ll have a nice addition of a clamp to your face frame (or start over with a new frame piece).
Jarod
-- Dad: Someone was supposed to pick up his toys! Son: My name isn't "Someone".
View Howie's profile
Howie
2656 posts in 2826 days
#3 posted 09-17-2012 11:52 PM
Yep,should be 1-1/4” for 3/4”. I’d try Jarod’s method.
-- Life is good.
BentheViking
#4 posted 09-18-2012 02:10 AM
Remember that part about where I said I had forgotten about how awesome the kit was…I guess I also forgot things like reading directions and about screw length. Fortunately it I stopped before it got too bad and hopefully some sanding and putty will have it all set (its getting painted). Thanks for the help, but getting back to the question of whether or not setting it for thinner wood would be useful or not?
View AKAndrew's profile
AKAndrew
53 posts in 2678 days
#5 posted 09-18-2012 06:12 AM
I always test fit holes, and yes, I have used shorter settings and shorter screws than the jig calls for.
