Electrical short
Forum topic by mark76wa posted 09-17-2012 05:35 AM 953 views 1 time favorited 5 replies Add to Favorites Watch
View mark76wa's profile
mark76wa
97 posts in 3297 days
09-17-2012 05:35 AM
I’m not sure what happened. I plugged in my contractor saw, made a few cuts with no problem. When I went to unplug it I was these pics.
The wall side has no marks or anything. There was no bogging or anything that would indicate a power drain. I didn’t see a flash (the plug was behind the saw and on the ground though) nor did I smell anything.
Any ideas? And more importantly, what do I do know?
Mark
5 replies so far
View fussy's profile
fussy
980 posts in 2952 days
#1 posted 09-17-2012 07:46 AM
Put a new plug on your saw (making sure to get the right amperage rating) and throw away the extension cord/multi-tap.
Steve
View Tennessee's profile
Tennessee
2738 posts in 2416 days
#2 posted 09-17-2012 10:47 AM
Pretty much agree with Steve. What happened is the extension cord connection inside the orange plug more than likely became loose, causing the arc inside the extension cord. 120VAC can jump with the right amperage, and your saw was drawing it, so the arc happened.
You need to obviously replace the plug on the saw, and I would buy a heavy duty extension cord with only one plug on it.
View EEngineer's profile
EEngineer
1089 posts in 3515 days
#3 posted 09-17-2012 11:50 AM
I don’t believe this was a short either. Like Tennessee, I suspect a loose connection inside the orange extension cord. I don’t like those cheap damned extension cords – I’ve had way too many failures like this. They get “tired” after a lot of use and just don’t maintain enough pressure to guarantee a good contact. Also, that cheap molded plug on your saw doesn’t look like it is rated for heavy current. Is that what came with the saw originally?
mark76wa
#4 posted 09-18-2012 12:38 AM
Thanks guys. I’ll chuck the orange cord and put a new plug on my Saw.
TopamaxSurvivor
18188 posts in 3577 days
#5 posted 09-18-2012 03:34 AM
Yup, just wore out and got too loose. Happens all the time ;-)
