Glue Removal
Forum topic by missingdigitworkshop posted 09-16-2012 08:04 PM 848 views 0 times favorited 4 replies Add to Favorites Watch
View missingdigitworkshop's profile
148 posts in 3031 days
09-16-2012 08:04 PM
Topic tags/keywords: question trick
I have recently rescued several feet of 3/4 ply that is covered on both sides with laminate. I have removed the laminate with a heat gun but can not seem find a good way to get rid of the glue.
Does anyone know of a way to get rid of the glue or is it a lost cause?
I would really hate to see this go to waste.
-- Do not be discouraged by those who don't. Be inspired by those who do.
Rick Dennington
5692 posts in 3097 days
#1 posted 09-16-2012 10:55 PM
I would take a card scraper or glue scraper and try to get as much off as I could…..soak the glue in Naptha or lighter fluid before trying to remove it…..let it penetrate for a bit, then try to remove with above items…...if it won’t come off, then just set it a fire and burn it…...no…just joshing….it may take a little or a lot of work, but it will eventually give up….....then just clean up the leftovers….........!!!!!!!!!
View huff's profile
huff
2828 posts in 3188 days
#2 posted 09-16-2012 11:45 PM
Naptha will probably work as good as anything to loosen the glue. Lighter fluid would also work, but I’m not sure you can buy that in quarts or gallons. Whenever I did a laminate countertop, I would use Naptha to clean up any glue that was left on any surface. You can usually find it at any of the big box stores. What you will pay for enough Naptha or any other material to clean up both sides of that plywood may cost you more then just buying plywood, especially if you count your time, but then again, who wants to waste a good piece of plywood. lol
-- John @ http://www.thehuffordfurnituregroup.com
#3 posted 09-16-2012 11:51 PM
Thanks guys!
View NiteWalker's profile
NiteWalker
2736 posts in 2480 days
#4 posted 09-17-2012 04:11 AM
Acetone.
It will come right up.
