Porter Cable 14" Bandsaw riser block for PCB330BS
Forum topic by Howarddavidp posted 09-16-2012 06:35 AM 20845 views 5 times favorited 81 replies Add to Favorites Watch
View Howarddavidp's profile
Howarddavidp
7 posts in 1977 days
09-16-2012 06:35 AM
I have a Porter Cable 14” PCB330BS saw. From reading on the net, I saw others have used the Jet risers on their Porter Cable 14” bandsaws. When I first opened the Jet Riser box, it looked like it would fit right away. I also thought this was only the block, and not a complete kit! This made me pleasantly surprised that everything I needed was included for $109. The extended round post for the blade guard is included, and it fits exactly like it was made for the Porter Cable saw. I knew previously that the PC and the Jet used similar guides, because when I called Carter to purchase roller guides, they said that the Porter Cable saw uses the Jet roller guide kit since they do not make a specific kit for the Porter Cable. They were right, and the Jet kit works like it was made for the PCB330BS, so these kits are one in the same.
Like previously mentioned, you need to drill 2 small holes, which was not hard to do. Take your time and measure with a caliper before cutting. As for honing out the hole, like the others have said, this is really only necessary to use 1/2” or 3/4” blades. If you only use a 1/4” or 1/8” blade, this might not be necessary since there is enough room without expanding the inside diameter of the block. I know that the specs say the max blade width for this saw is 1/2”, but many have seen you can in fact use a 3/4” 1-TPI hook blade for big resawing jobs. The wheels and tires are big enough for using the bigger blades.
So, if you want a riser for you Porter Cable PCB330BS, this is the one to get. This is closest to the kit that Porter Cable has never made.
I would estimate 3 hours time to do the complete project, and sell or give away your 93.5” blades, as you will now move up to 105” blades. Oh yeah, a nice touch is that they give you a 105” 10 TPI 3/8 blade to get started with, so you can test it once you are done. You will need a 3/8 speed/steel bit for drilling the holes, and you will need some type of sanding, honing device to make the block opening slightly bigger. Sandpaper drill bits, like the kind used for sanding holes with your drill, will also work fine. You don’t need a nice finish, so 60 or 80 grit will work. Nobody will ever see this hole once you are done, so don’t worry about doing a “clean” job when you are opening up the hole.
Once you are done, you can now resaw 12” thick stock with a 3/4” 1 TPI hook blade very nicely. The saw has enough power to do this with the stock motor, which can be upgraded if needed. I am sure this block would void your warranty, but if your saw breaks it is easy enough to revert your saw back to stock and only you will be the wiser. None of the mods are done to your saw, you only modify the block to fit your saw.
ENJOY!
Woodcraft Item Number = Item #961137
http://www.woodcraft.com/product/200...ser-block.aspx
81 replies so far
View GrandpaLen's profile
GrandpaLen
1648 posts in 2146 days
#1 posted 09-16-2012 02:15 PM
Welcome to LumberJocks , a world of advise, opinions, and experiences, all shared without judgement.
Hey, Thanks for that great reference info, I’m sure that one of the LJs will appreciate this in their future conversion.
Work Safely and have Fun. – Grandpa Len
-- Mother Nature should be proud of what you've done with her tree. - Len ...just north of a stone's throw from the oHIo, river that is, in So. Indiana.
View Surfside's profile
Surfside
3389 posts in 2047 days
#2 posted 09-17-2012 02:21 PM
Welcome to LJ! Nice information you got there, Howard! Thanks!
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View FlatheadRed's profile
FlatheadRed
3 posts in 2011 days
#3 posted 11-27-2012 07:42 PM
That’s awesome! I bought the P/C saw as it was very reasonably priced. I did see the big drawback with no riser blocks but was willing to overlook that as I didn’t see a need for the riser blocks. I’m glad they fit as I will get one to allow me the flexiblity of a 12” cut.
Red
-- Every immigrant who comes here should be required within five years to learn English or leave the country. Theodore Roosevelt
FlatheadRed
#4 posted 12-01-2012 12:01 AM
I have an update. This did not work for me. While Howard was correct in that two new holes must be drilled in order for it to fit, I found that the bar that holds the upper guides and allows them to be adjusted up and down doesn’t fit. Additionally, when you remove the old one (P-C) a spring with a ball bearing comes out which is near impossible to remove. Also the rear chain guard does fit but not well. I know that it was my call to purchase this but I’m out the money. I would advise against doing this mod.
Red
Howarddavidp
#5 posted 12-03-2012 02:58 AM
Hey Red,
Do you live on the East Coast? I might be able to make a weekend roadtrip and make that fit for you.
Use some 220 grit sandpaper on the guide bar that slides, that will make it fit better. As for the bearing and spring, I used masking tape to hold mine in place when I re-assembled it, then pulled the tape out once it was back together.
As for the rear guide, I did have to bend mine to get it to fit, but once it did, I never had any issues.
Let me be clear: This kit is not made for this saw. It will work, and I have yet to see something closer to the right block for this saw. But, you will need to make some mods to the pieces in the kit for them to fit exactly, and by exactly I mean close enough to use the saw without problems, but not what one would call a “perfect fit”. Funny thing is, even with the fit of this riser, it was no worse of a fit that the pieces on my HF saw, which worked great and I loved, but the molds needed some TLC to fit better (and never fit 100%). Let’s face it, if you have $750 to spare, go get a Grizzly G05??, that will be the best and comes with a riser…
View el_viejo's profile
el_viejo
2 posts in 1868 days
#6 posted 12-09-2012 06:58 PM
Gentlemen, thank you all for taking the time to record your experiences. Red, I particularly appreciate the negative information since that provides critical warnings. Given the rest of what I’ve read, I’m going to take the risk and give it a try.
I’m very disapointed that Porter Cable has not provided a riser for this saw. It is otherwise an excellent value and the 10 amp motor can certainly handle resawing stock larger than 6”.
View Shawn1015's profile
Shawn1015
6 posts in 1867 days
#7 posted 12-10-2012 07:41 PM
I wanted add my comments to this post. I took a chance on the Jet riser and had success. It did take me close to 4 hours to get it to work. If you don’t want to take that amount of time then I would recommend you look at a different option. For me I am stuck with the PC 14” bandsaw and don’t have the extra cash for a new saw with the extra 6”.
I had to drill new holes for the riser to make it fit the PC. I used poster board to make an impression of the base to ensure the alignment of the pin locations. I then transfered that pattern to the riser block and drilled the new pin holes. I used regular drill bit for steel and had no problems. Once I got the riser block on, I then checked the alignment with the top and bottom wheels and had to do a little shimming to get the vertical alignment right.
The new guide bar was painted black and I used a hand sander and removed all the paint and took it the bare rod and it fit really well. I tired to slide the new one in place of the old one and the spring and ball bearing did come out but I had no problem putting in back in. The most time I spent was filing/sanding down the lower bout of the bar so the lower portion of the guide would fit. I also had to do a little filing on the back of the new blade guard so it would fit flush with the new riser.
After I leveled and tuned up the blocks/wheels it worked really well and I am very pleased. I hope this helps someone else.
View Crankynow's profile
Crankynow
1 post in 1219 days
#8 posted 09-19-2014 06:13 PM
I just got off the phone with porter cable at 888-609-9779 customer service. Asked if they have a riser for the band saw. They said sure! I placed the order wth them and it will be delivered in 7 to 10 days. So for those that say there is not something from the OEM, better check back with them. Will report back when I have the riser and install it on the PCB330BS that I bought at Lowes.
View Marsher52's profile
Marsher52
24 posts in 1135 days
#9 posted 12-11-2014 08:10 PM
Crankynow….. how did you make out getting this conversion kit from Porter Cable ????
View paintbug's profile
paintbug
1 post in 1135 days
#10 posted 12-12-2014 02:14 PM
- Crankynow
Do you have the part # for that riser kit?? How did it work out for you?
el_viejo
#11 posted 12-12-2014 04:37 PM
Some time back I decided to buy the Jet riser kit for my Porter-Cable. Before I give a summary of the results, I would like to provide this link to a fairly complete blog entry that details the installation process. It sounds like the writer of that blog had a pretty easy time of it, though he ran into the same range of difficulties I did. My experience did not flow as easily as his description. If you are equipped to handle some modest metal working, the process isn’t all that bad, but it does take work and precision.
I have been using the Porter-Cable 14” bandsaw with Jet riser for over 18 months. As I originally believed, the large motor was adequate for all the cutting I have attempted, including resawing hardwoods 10” thick.
The upper guide bearings require more tweaking with the greater range of thicknesses shouldn’t be the case if the frame is perfectly aligned and stable. This may be my problem rather than a general problem since I had some difficulty getting the riser block well aligned to the frame and had to drill out the holes to a wider diameter than the alignment pins. Also, I was not satisfied with the squareness and added shims to the inside edge of the riser block. As I say, could be my problem, but read on.
I had hoped to use ¾” or even 1” blades for resawing. This is where I ran into real headaches. The tensioner on the saw is calibrated for blades up to 1”. However, the mechanism is way to flimsy to actually do that. The base against which the tensioning mechanism pushes is nothing more than the rough, cast iron body of the saw which is actually sloped. As pressure is applied, the sloped surface causes the rod slide inward toward the upper wheel. To compensate, I added a shaed piece of wood with a washer to receive the rod. That didn’t solve the problem because the threaded rod that exerts the tensioning force is too thin and has a tendency to bend under too much force. Also, the handle provided to turn the rod is small, which limits how much force you can apply. I have never tensioned it beyond the ¾” setting and I do not actually use it beyond about 5/8” because of concern for the rod.
Bottom line, the saw is great for cutting curves and some resawing, but I cannot use it as planned. I am not satisfied and do not recommend this approach, though it is viable for someone pinching pennies. I will be buying a steel frame saw. Even so, I still think this saw is by far the best value in small band saws.
Marsher52
#12 posted 01-20-2015 03:21 PM
I just ordered the riser kit from Porter Cable… Part number X0JX… cost is 80.49 plus shipping.
Shipping to Canada is high $27.00
of course all in USF so have to add 20% for exchange.
View beautat's profile
beautat
22 posts in 1062 days
#13 posted 02-23-2015 04:30 PM
Riser block kit for Porter cable PCB330BS = part # : XOJX——- $80.49 (blade ,block ,all hardware)
Rip fence for Porter Cable PCB330BS = part # : X4CT————$49.99
gonna order mine soon…..........
will let you know how it works!!!!!!!!!!!!!!!!!
Marsher52
#14 posted 02-24-2015 12:27 AM
I got mine end of Jan. have to say that for the most part install was were easy… took about 1 hour. did find that the capacity was not the stated 12” due to the fact that the blade guard would not go high enough…. it hit on the radius of the upper housing. a little work with a grinder on the top of the guard and all is well. as expected had to re-track the saw, but that was easily done.
Running a 9/16 3 tooth blade. Have yet to change to the 1/8 scroll blade.
beautat
#15 posted 02-26-2015 02:54 PM
Got mine yesterday and the rip fence they offer. Also the blade guard on the power side had to be tweeked. If u take the whole bolt loose that holds guard to saw behind it is a washer that can be taken out of both top and lower bracket now its not sloppy anymore. I had no instructions to go by only took two hours to put on block and fence. It only took one day to get it!!!!!!!Works great though.
showing 1 through 15 of 81 replies
