Spraying latex with hvlp?
Forum topic by rut posted 251 days ago 843 views 2 times favorited 7 replies Add to Favorites Watch
View rut's profile
rut
81 posts in 554 days
251 days ago
So I’ve been trying to spray latex on my kitchen panels using a rockler hvlp sprayer. I found I had to thin it tremendously to get it to even spray. Now the problem I have is that I still get some sputtering.
Is there a better way to get a smooth finish? Airless sprayer perhaps? I got a nice coat of shellac based primer on it and sanded smooth with 400 grit. Would like to get as nice a paint finish as the primer.
Thanks,
Rut
7 replies so far
View Jeremy Greiner's profile
Jeremy Greiner
511 posts in 944 days
#1 posted 251 days ago
I haven’t had a lot of luck myself with the same HVLP unit .. so I’m interested in any thoughts as well.
-- Easy to use end grain cutting board designer: http://www.1024studios.com/cuttingboard.html
View huff's profile
huff
2559 posts in 1457 days
#2 posted 251 days ago
rut, I learned a trick about spraying latex from Earlextech so I copied his advice and see what you think. The molecules in latex are like spagetti, long and thin, imagine trying to get spagetti to line up so that you can spray it through a 1.5mm opening, nearly impossible, right? Using the mixer in a drill will shear the paint and it will chop up all of those long stringy molecules. All airless systems use this to their advantage by hiding a shearing blade inside the head unit and chopping the paint as it goes through. Hope this will help you spraying latex.
-- John @ http://www.thehuffordfurnituregroup.com
View huff's profile
huff
#3 posted 251 days ago
I forgot to mention; for the Earlex, he only thins latex about 10%. I don’t know if that will work for the Rockler HVLP, but using a mixer instead of just stirring the latex, I would probably start by thinning about 10% and practice on some scrap and go from there. Good luck and let us know how you make out.
View Gshepherd's profile
Gshepherd
1363 posts in 373 days
#4 posted 251 days ago
Had same problems, I used paint mixer on my drill and really mixed up very well and thinned it some and then used a paint strainer before it went into the cup. Made a few needle adjustments and all worked out well.
-- What we do in life will Echo through Eternity........
View rut's profile
rut
#5 posted 251 days ago
Interesting. I actually have been using a drill mixer anyway but still had to thin probably by 25% to get it to spray. I finally decided to give it up and purchased a graco airless sprayer that is supposed to be able to handle latex unthinned. Well see.
Thanks for the suggestions. I’ll let you know how the graco works.
Rut
View rut's profile
rut
#6 posted 228 days ago
Just an update. I think I finally found the secret to a smooth latex finish. Using the graco truecoat airless sprayer with latex I was able to spray my cab faceframes and they dried nice and smooth.
The graco really throws out the paint. So much so that I was sure I would have way too much. It even looked a bit orange peelish after first spraying. I think the real secret was the addition of floetrol to the paint. I added almost a quart of floetrol to a gallon of paint. This allowed the paint to stay wetter longer and the paint smoothed out and dried nice and smooth.
While others may have luck with an hvlp setup, I think I’ll do it this way. I actually believe you can get it smooth just using a brush with the floetrol added. It really helps.
Rut
View cutworm's profile
cutworm
685 posts in 965 days
#7 posted 228 days ago
I use GF Milk Paint in mine with good results. Thinned about 20%. Haven’t tried latex. It just looks too thick. The Milk Paint is actually acrylic or so I’m told.
-- "Actions speak louder than words but not nearly as often." - Mark Twain
