Cutting out wood crosses/advice needed
Forum topic by UndertheSonMosaics posted 09-15-2012 12:48 AM 1924 views 0 times favorited 3 replies Add to Favorites Watch
View UndertheSonMosaics's profile
UndertheSonMosaics
2 posts in 2049 days
09-15-2012 12:48 AM
Hi everyone! I am “attempting” to cut out some wooden crosses from plywood. At the moment I am doing this with a jigsaw, which is time consuming. Is there another way to cut these patterns out, that would be better on my time? The patterns are not real detailed, a few curves here and there, but for the most part, nothing fancy.
I would appreciate any advice you could offer. Thank you!
3 replies so far
View AandCstyle's profile
AandCstyle
3027 posts in 2226 days
#1 posted 09-15-2012 12:52 AM
If you are making a number of the same design and if you have a router, you could make a template with thin stock (masonite or 1/4”MDF), then use the router with a bearing guided straight cutting bit. HTH
-- Art
View derosa's profile
derosa
1572 posts in 2805 days
#2 posted 09-15-2012 02:34 AM
Thin blade on the bandsaw or scrollsaw. Either is liable to be a little faster then a jigsaw and probably safer; if you don’t have either the jigsaw is probably it.
-- --Rev. Russ in NY-- A posse ad esse
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3127 days
#3 posted 09-15-2012 03:30 AM
I’d probably stack a few boards with double sided tape and use the band saw.
-- jay, www.allaboutastro.com
