Twisted boards!
Forum topic by AJswoodshop posted 09-14-2012 05:01 PM 1415 views 0 times favorited 9 replies Add to Favorites Watch
View AJswoodshop's profile
AJswoodshop
1057 posts in 2146 days
09-14-2012 05:01 PM
Has this ever happened to you?
I was buying some lumber yesterday, and I needed one 2+4. I probably went through 50 2+4 until I found one that was straight! That’s crazy!
AJ
9 replies so far
View Jim Jakosh's profile
Jim Jakosh
19943 posts in 2975 days
#1 posted 09-14-2012 05:04 PM
AJ, they don’t hardly dry them anymore. They move like a green bowl in the lathe and some look like snakes!
You have to hurry and nail them in place if you making a wall just to have chance!
AJswoodshop
#2 posted 09-14-2012 05:09 PM
That’s true, most of the time when I get a board, it’s a little damp.
Thanks for the comment Jim,
AJ
View Dallas's profile
Dallas
3599 posts in 2356 days
#3 posted 09-14-2012 05:58 PM
AJ, take your trusty moisture meter with you next time. You’ll be surprised how wet construction grade wood is.
When I buy AC 3/4” exterior plywood I have to let it sit for a couple of months just so I can lift it…. the wife helps me carry it in!
View Grandpa's profile
Grandpa
3259 posts in 2545 days
#4 posted 09-15-2012 04:03 AM
You have to keep your 2×4’s out of the sunshine too. They will warp and twist around like a snake if one side of the board is dried by the sun. Never let the sun get on your wood or you are inviting trouble.
View Grumpymike's profile
Grumpymike
2190 posts in 2185 days
#5 posted 09-15-2012 06:49 PM
AJ,
Grandpa is very correct about the sun … I bought a bunch of 1X4 pine at HD, carefull to select the best ones in the pile, put them in the back of the pick-up and drove home, the wife wanted to stop by the grocery store so we did. (We live several miles from a store so we only go about once a week) we got home about an hour after loading the lumber and as I offloaded the boards the Arizoma sun had twisted them into 8’ airplane propellers. I now cover my load, it helps.
As Dallas suggests pick up a moisture meter. I have two, one in the shop ( the good one) and a cheapie (about $20) that I carry in the PU.
Buy a few extra 2X4’s and store them in your shop to let them dry and cure for a while, you’ll get better results.
-- Grumpy old guy, and lookin' good Doin' it. ... Surprise Az.
View cutmantom's profile
cutmantom
401 posts in 2904 days
#6 posted 09-15-2012 07:06 PM
you found a straight one?
View IsaacH's profile
IsaacH
128 posts in 1966 days
#7 posted 09-15-2012 08:03 PM
I found that If you go ahead and dig down 1/3 of the way to the bottom of the pile, you get to boards that havn’t been picked through yet. Its easier to find reasonably straight ones. The top jumbled third are the ones that other people have already rejected.
Now keeping them straight….sticker and stack, top off with weights. Wont get rid of all the twist, but it will help.
-- Isaac- Decatur, GA - "Your woodworking....NOT machining parts for NASA!!!"
View sedcokid's profile
sedcokid
2729 posts in 3468 days
#8 posted 09-17-2012 12:59 AM
I have had problems too…..... But I also have found out that if you dig deep enough you WILL find a straight one.
Good Forum topic!
-- Chuck Emery, Michigan,
View Steve Peterson's profile
Steve Peterson
361 posts in 2952 days
#9 posted 09-17-2012 05:57 PM
Sometimes it is just luck to show up at the big box store on a day when a fresh bundle has just been opened.
Other days you have to sort through other people’s rejects. The store employees job is to re-stack them as neat as possible to make them look like a fresh stack. The bundles usually have a few thin stickers in them. I usually try to dig below the stickers in hopes of getting a few that have not been picked through.
-- Steve
