| Forum topic by Lee Barker | posted 250 days ago | 429 views | 0 times favorited | 8 replies | ![]() |
250 days ago |
...and now you know they all will eventually? Schniggledorf recently posted about a single incident and it led me to ponder this larger problem. Would it make sense to develop a router frame sort of jig and relieve the center (thicker) part of the panel from the back? It sounds brutal, but I’m wondering if you reduced that thickness to 3/8 or so if the panel would lack the heft to split the frame joints. All speculation and explanation welcomed! Kindly, Lee -- "...in his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It" |
8 replies so far
#1 posted 198 days ago |
I use black rubber space balls 1/4” diameter (from Rockler) 2 to 3 balls on each side. No problems so far. -- Love thy neighbour as thyself |
#2 posted 198 days ago |
Lee, -- HorizontalMike -- "Woodpeckers understand..." |
#3 posted 198 days ago |
It would be an elaborate and perhaps unsuccessful fix Another form of door doctoring might be to saw |
#4 posted 198 days ago |
”...top the door might bulge outwards seasonally….” That is what it sounds like to me as well. And as far as attempting elaborate fixes, I would think it much easier (if/when the need were to arise) to just cut the rails and stiles OFF and re-frame the panel completely. The only challenge then would be matching stain/finish. Thanks for the input. -- HorizontalMike -- "Woodpeckers understand..." |
#5 posted 198 days ago |
I would probably attempt to reinforce joints instead, either with pocket screws or a spline. I would also consider coming through the top and bottom edges as well, perhaps with countersunk screws with dowel plugs. They wouldn’t noticeable on the edge of the doors. Heck, metal staples or corrugated wood joiners would work. Now, if the issue is caused by too much expansion in the panel beyond the space provided by the grooves, then I can’t think of a solution for that. -- jay, www.allaboutastro.com |
#6 posted 198 days ago |
two things can affect the panel lifespan when the rails/styles are glued together the other thing that can effect the panels i have seen in the corners a split in the panel edge even though they are slightly smaller than the space allowed i do use spaceballs now too -- david - only thru kindness can this world be whole . If we don't succeed we run the risk of failure. Dan Quayle |
#7 posted 198 days ago |
Thanks Jay. I currently do not have an issue on anything of value, but found this topic to be thought provoking for future fixes. I do have an old HD prefab paneled cabinet door that my mother converted(arts&crafts) to a hanging mirror frame some +30-40 years ago, that has now expanded and split at the upper stile on one side. Minor, but may try experimenting with that one for the heck of it. The split is there yet all is still solid framewise. Coming from the backside and essentially making a spline/butterfly would be easy enough, to hold things right where they currently are. Drilling for dowels and/or screws, however, would be more difficult unless you own very long 1/4” or 3/8” drill bits. -- HorizontalMike -- "Woodpeckers understand..." |
#8 posted 198 days ago |
David, -- HorizontalMike -- "Woodpeckers understand..." |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1534 |
3550 |
15787 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6159 |
