What Would You Do With $900?
Forum topic by stidrvr posted 09-13-2012 08:31 AM 1883 views 0 times favorited 51 replies Add to Favorites Watch
View stidrvr's profile
stidrvr
40 posts in 3679 days
09-13-2012 08:31 AM
Here’s the deal. I’ve got $900 to spend on anything. I’ve been racking my brain what to do with it. First here’s where I’m at:
I already have:
Table saw (ts3650)
12” Sliding compound miter saw
Circular saw
Fixed base router
Various drills
Piss poor clamp collection
Kreg Jig
RO sander
Clear Vue mini cyclone
Ideas that I’ve thought of:
I’d love to start the move to festool
Domino
Of1400
Ts55
Hold out for menards made in USA sale and buy a ton of Jorgesen parallel clamps
Upgrade mitre gauge for table saw
Possible jointer and planer (used Craigslist?)
What would you do? Open to other ideas not listed as well.
51 replies so far
404 - Not Found
2544 posts in 3173 days
#1 posted 09-13-2012 09:04 AM
Jointer/Planer to keep the tablesaw company would be my priority, and if there’s any change, some new clamps, but it depends on the type of work you do.
View lunn's profile
lunn
215 posts in 2513 days
#2 posted 09-13-2012 10:19 AM
A high rise intake, Holly 4bbl dbl pumper carb and a tank of gas for my REO. And 1 clamp. To many hobbies! ! A planer for sure.
-- What started as a hobbie is now a full time JOB!
View knotscott's profile
knotscott
8151 posts in 3580 days
#3 posted 09-13-2012 10:46 AM
If you use dimensioned lumber, a planer and jointer is a game changer (in your favor). Used is fine if the right deal comes along, but you could get a decent new planer and jointer if you’re careful. Buy the big stuff with that chunk…smaller stuff is easier to acquire with lunch and birthday money.
A variable speed router for a router table adds another dimension too.
Parallel clamps are great…start with a couple, and add more when you can as needed….Jet, Stanley, Woodcraft…all good. The HF Pittsburg bar clamps are a good value to pad your collection without breaking the bank.
How’s your saw blade inventory?
View Tom Godfrey's profile
Tom Godfrey
488 posts in 2380 days
#4 posted 09-13-2012 10:59 AM
The best thing you could do with that money is send it to me and then your worries are over. No more having to think about even having that money.
All jokes aside planner for sure. I like to be able to plane my lumber to the thickness I desire.
Good luck on making that decision
-- Tom Godfrey Landrum South Carolina (tomhcww@gmail.com)
HillbillyShooter
5811 posts in 2496 days
#5 posted 09-13-2012 12:23 PM
Jointer first and planer second—if you don’t get it straight and all twists out first, all the planer will do is produce a thinner board with the same curves and twists. JMHO.
View KnickKnack's profile
KnickKnack
1094 posts in 3771 days
#6 posted 09-13-2012 12:34 PM
If, as you say, you’ve been “racking my brain what to do with it”, I’d suggest that you wait, and spend it when a project requires something. I have a whole bunch of clamps (well, about 5, and they were cheap), that I find are just a bit small for a lot of the things I work on – if I’d waited until I needed clamps for a project, I’d have got the slightly bigger version. Not a fun answer – sorry.
-- "Do not speak – unless it improves on silence." --- "Following the rules and protecting the regulations is binding oneself without rope."
View NedB's profile
NedB
659 posts in 3770 days
#7 posted 09-13-2012 12:35 PM
+1 on the jointer and planer.
With those two tools you go from working with dimensional lumber to rough cut boards which you can then prep to your specific needs.
I see you have a fixed base router… hmmm, variation on a theme:
portable planer, router table and a 14” bandsaw.
Planer allows you to take rough lumber to thickness, the router table can edge joint your workpieces (among many other tasks) & the bandsaw will allow you to re-saw for thinner stock.
-- Ned - 2B1ASK1 http://nedswoodshop.blogspot.com
View muleskinner's profile
muleskinner
919 posts in 2641 days
#8 posted 09-13-2012 12:54 PM
If I had your tools and $900 and considering my projects I would get a 6” jointer, a bandsaw, and stationary belt sander. I’d scour CraigsList and garage sales and hopefully have some change left over for accessories like clamps. But thats me. Your mileage may vary depending on what you want to build.
-- Visualize whirled peas
Beginningwoodworker
13345 posts in 3877 days
#9 posted 09-13-2012 01:03 PM
Yes you need a jointer and a planer.
View pmayer's profile
pmayer
1032 posts in 3269 days
#10 posted 09-13-2012 01:37 PM
I would get an 8” jointer now and get a planer with your next windfall. If you try to get planer and joiner with $900 you will end up upgrading later and it will cost more.
View Surfside's profile
Surfside
3389 posts in 2378 days
#11 posted 09-13-2012 02:05 PM
Haven’t you thought of a band saw? Of course, with a good quality band saw blade and a mobile base. And add a riser kit if you like.
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View grfrazee's profile
grfrazee
388 posts in 2344 days
#12 posted 09-13-2012 02:11 PM
I’ll chime in with jointer and planer first. I’ll also say to check craigslist – I’ve seen some relatively new used tools for decent prices in my area that I probably would have bought if my dad didn’t already have them.
Also, you can NEVER have enough clamps. I’m a big fan of the Bessey/Jet parallel clamps. Hard (in my experience at least) to find them used, however.
-- -=Pride is not a sin=-
View JayT's profile
JayT
5961 posts in 2415 days
#13 posted 09-13-2012 02:18 PM
What kind of woodworking projects do you do? What ones do you want to do that you don’t feel have been possible with your current tools?
Once those questions are answered, then it will lead to the answer for how to best invest the money. (Yeah, I don’t spend money on woodworking, I invest it. Sounds better when justifying a purchase to the wife.)
View Smitty_Cabinetshop's profile (online now)
Smitty_Cabinetshop
15703 posts in 2823 days
#14 posted 09-13-2012 02:44 PM
Buy a vintage jack, jointer and smoother set of planes and a sharpening setup, then save the remaining $650 for a project that needs a specific tool.
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3363 days
#15 posted 09-13-2012 03:29 PM
Planer, planer, planer!
-- jay, www.allaboutastro.com
showing 1 through 15 of 51 replies
