Rail and stiles by hand , What tool?
11K views 20 replies 15 participants last post by  Stephenw
#1 · (Edited by Moderator)
Is there such a HAND tool to cut rail and stile cabinet doors, so a router is not needed? What tools would it be?
I have searched google but the only method i can find is with a rail and stile router bit.
#5 ·
The way it is done is all the stock is profiled the same and then
you miter the molded portion. So you need a plane to excavate
a 1/4" channel for your panel and another plane to make
an identical profile on all parts on the front inside edge
of the frame. You can make them square like the shakers
if you like, but you still have to miter the insides of the frame.
It's not that hard to do the mitered inside corners on a frame
by hand. A lion miter trimmer or a miter jack is nice to have.
The trickiest part is cutting the tenons accurately by hand.
The stiles are usually left long when mortising and then
the "horns" cut off after assembly.
#7 ·
I have an old Craftsmen combination plane, my Father handed down to me. It's a wonderful tool. If you want to use hand tools, this would be invalueable. Numerous profiles, about the only thing it doesn't cut is a cove. I know some companies still make this plane, but you'll have to search.
#8 · (Edited by Moderator)
I used Roy's method that he did a WoodWright's show on, here's what I used:
trusty rusty back saw: rip stock to width, cut stock to lengths/pieces, cut tennons
, cut off horns
small bevel up smoother: joint rip cut, clean up stock, size/square pieces after cutting, clean up and size frame after assembly
1/4" mortice chisel: cut mortices
1/4" plow plane: cut grooves
butt chisels: pare tennons, make chips to fill voids around tennon tails (which fill the exposed groove end)
shoulder plane: even up tennon shoulders across pieces, shave cheeks
1/4" drill bit and cordless drill: drill holes for dowels/pins
flush cut saw: cut off dowel ends
low angle block plane (purchased after frame assembly): chamfer frame edges
#12 ·
Tirebob and others: Chris Carr is obviously trying to figure out how to cope a profiled rail into a stile. For that, a mirror-image profile cutter is necessary in order to match the rail and stile joint. Indeed, a wooden molding plane would work, but they are exceptionally rare. There might be a reverse-profile cutter for a Stanley 45, but that would be a tough cut to make with that plane on the end grain of a narrow stick.
#13 ·
#15 ·
The #55 is an option. The down side is metal multi-planes pretty much suck compared to wooden planes. They are the epitome of "jack of all trades - master of none."There is no support ahead of the iron and they tear out. They also have poor guidance. I have a #45 and I can attest to that. They had some extra soles that you could add to a #45 for hollows and rounds that supposedly did better but they are pretty rare.The one exception is the absolutely gorgeous little multi-plane that Bridge City Toolworks sells. It has replaceable soles to match each profile. Not cheap but a beautifully made tool… as usual for them.
If you contact some of the tool pushers, you can get wooden planes in the profiles you are looking for. There are a lot of different profiles around in different styles and sizes. This was how things like that were made before routers. Generally, they are not made from only one plane except in the smallest sizes. You make several cuts with different planes until you have the desired profile.
If you are not making a lot of it, you can also do it with your own made scratch stocks. Basic idea is that you rough out the shape and then use a scraper cut to the profile to finish up.
Unfortunately many of these planes are no longer made. Your alternatives are: Buy vintage, get some from the few makers that are still making them, or make them yourself. The making it yourself can range from working from scratch or you can accelerate the process by picking up old molding planes and re-shaping them to what you want. This is primarily done as above with a scratch stock to shape the plane and then grind the iron to match.
#16 ·
Mike Dunbar wrote an excellent article called Colonial Cupboard on how to practice using hand tools to make 9 kinds of joints by building a simple cupboard with a dovetailed box, frame and floating raised panel door, coped thumbnail profile at the mortise and tenon joints, crown molding, ship lapped back, dadoes, etc. He describes the hand tools used with step by step instructions and a detailed drawing. I used it to make the cabinet; works. The article is in the collection Handtool Skills published by Fine Woodworking in 2008 but the article I believe appeared earlier in the magazine. You should be able to google it and download a PDF.
#18 · (Edited by Moderator)
Derek Cohen shows it all.
Although my IKEA kitchen uses profile and counter-profile with no problem after 10 or 15 years, I would think the traditional method illustrated by Derek is more appropriate for long term solidity and stability.
If you don't have to make hundreds of it in a short time it is worth the little extra work. It might also be frustrating trying to do the counter profile on end grain by hand and finally it might take more time.
for moulding look at the site of Matt Bickford
http://musingsfrombigpink.blogspot.be/
very interesting
He is also manufacturing and selling moulding planes on his other site
http://www.msbickford.com/
I have bought a pair of hollow and round on a flea market for about 5,-EURO
