Attaching Patterns to wood..
Forum topic by Alexandre posted 09-12-2012 08:45 PM 1527 views 0 times favorited 11 replies Add to Favorites Watch
View Alexandre's profile
1417 posts in 2123 days
09-12-2012 08:45 PM
Topic tags/keywords: scrollsaw bandsaw pattern wood question
What is your method of attaching patterns to wood to cut out on the scrollsaw, bandsaw etc…
What do you use?
I personally use Glue stick, That stuff you find at stationary stores.
The good glue sticks work well for me. I rub some on the paper, then I put it on the wood.
What is your method?
-- My terrible signature...
11 replies so far
View mtenterprises's profile
933 posts in 2625 days
#1 posted 09-12-2012 09:01 PM
Rubber cement.
-- See pictures on Flickr - And visit my Facebook page -
404 - Not Found
2544 posts in 2901 days
#2 posted 09-12-2012 09:20 PM
Spray adhesive – the type for mounting photographs.
View Surfside's profile
3389 posts in 2106 days
#3 posted 09-12-2012 09:34 PM
Another glue stick user here!
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View DeputyDawg's profile
196 posts in 3897 days
#4 posted 09-12-2012 10:01 PM
I use to own a print shop and have always used 3M General purpose 45 Spray Adhasive, mainly because it is easy to get off.
-- DeputyDawg
View Jim Jakosh's profile
Jim Jakosh
20169 posts in 3038 days
#5 posted 09-12-2012 10:19 PM
I use a spray temporary adhesive.
#6 posted 09-13-2012 12:15 AM
Well, How do you guys take off the spray adhesive?
Is there a another thing you spray on?
View fussy's profile
980 posts in 2983 days
#7 posted 09-13-2012 07:17 AM
wet the pattern with mineral spirits, peel it off and follow up in the same way with adhesive left on the wood.
View TheDane's profile
5384 posts in 3595 days
#8 posted 09-13-2012 12:42 PM
I print in reverse on my laser printer, tape the pattern face down on the workpiece, then dab the paper with lacquer thinner. It transfers the toner image directly to the wood. Don’t soak the paper, just getting it damp is enough to transfer the image.
View Cosmicsniper's profile
2202 posts in 3091 days
#9 posted 09-13-2012 12:46 PM
I don’t do a lot of scroll work, but I have 3M spray adhesive on hand for when I do. It actually serves double duty for mounting pictures to museum board, which I do quite a bit.
-- jay,
View kepy's profile
293 posts in 2206 days
#10 posted 09-13-2012 01:13 PM
I apply blue painters tape to the wood first, then spray adhesive on the pattern and apply. When finished, it all peels off easily. If I’m stack cutting, I use the tape to hold the stack together.
-- Kepy
View Gene Howe's profile
Gene Howe
10253 posts in 3361 days
#11 posted 09-13-2012 01:13 PM
I apply blue masking tape to the wood, then apply the pattern to the tape with spray adhesive. I use 3M 77.
Then just remove the tape from the cut pieces. Lot easier and less messy than using thinner to remove.
