Started to build my chevalet
Forum topic by sandhill posted 09-12-2012 06:44 PM 1757 views 1 time favorited 30 replies Add to Favorites Watch
View sandhill's profile
sandhill
2128 posts in 3796 days
09-12-2012 06:44 PM
Topic tags/keywords: resource
So far I have made what you see here I hope the rest goes a little faster it took me 3 days to get this far because I cut the double mortice and dove tail by hand.
Thank you Shipwright for supplying the drawing and his blog I would never have done this otherwise.
30 replies so far
View SSG's profile
SSG
39 posts in 1955 days
#1 posted 09-12-2012 11:08 PM
It looks like you are off to a very nice start. Work to standard not to Time.
View Mathew Nedeljko's profile
Mathew Nedeljko
715 posts in 3702 days
#2 posted 09-13-2012 03:26 AM
Great start there Bob…glad to see that you are well underway. I will be following your progress, so please keep us updated regularly!
I may be mistaken, but it looks like the post is facing in the wrong direction, make sure you glue it in properly! The spacer that connects the foot to the bench is on the opposite side to the notch in the post that supports the arm.
-- Aim high. Ride easy. Trust God. Neale Donald Walsch
View shipwright's profile (online now)
shipwright
7848 posts in 2670 days
#3 posted 09-13-2012 05:30 AM
Good catch Mat. The post does have to turn around.
Great to see another one on the way Bob. We await the opportunity to welcome you top the club. :-)
I like your fancy column base.
Keep us posted.
sandhill
#4 posted 09-13-2012 02:35 PM
LOL your right thank you Matt I also noticed the photo is mirrored of what it should be but I fixed the photo now. I will be careful on the glue up Matt. My questions why the bolt if its glued? I was not going to glue it in case I wanted to break it down to move it, it’s a glove fit. I have to glue up some more 8/4 stock today so not much progress today I should get the arm, three clamping blocks and a few others done next week
Thanks Paul, I am also thinking of a profile for the corners.
shipwright
#5 posted 09-13-2012 03:49 PM
Why the bolt?... To fasten the bench to the column.
It cant hurt to give it a try with just the bolt if you want it to be more “portable”. The worst that can happen it that it “works” a little after a while and if it does, you can glue it then. I’m building one right now for a friend and with that joint glued it will ship in 3’ x4’ x 16”. In oak it weighs about 125 lbs.
sandhill
#6 posted 09-13-2012 03:59 PM
Paul where do you get your saw blades are they #6 in size? I bet you finish the one your building before I do I’m a slow poke when it comes to building anything.
sandhill
#7 posted 09-13-2012 09:24 PM
Hey guys I just finished making the 3 clamps that hold the horizontal arm and noticed that there are 4 bolts but they do not go through the two side block clamps? Is that an oversight in the sketch up drawing? I would guess they should if you want it to adjust up and down with wedges. I added a photo
View AandCstyle's profile
AandCstyle
2950 posts in 2129 days
#8 posted 09-14-2012 01:00 AM
I had to Google this to know what you are building! LOL At first, I thought it was an automobile. :D Guess I am just too ignorant about the finer points of wood working. :)
-- Art
sandhill
#9 posted 09-14-2012 02:20 AM
Not at all Art, I doubt many of us knew what it was before Paul built his.
Mathew Nedeljko
#10 posted 09-15-2012 05:22 AM
Bob by the way i forgot to mention that I really like the profile you used on the foot…that is going to look sharp!
View jackass's profile
jackass
350 posts in 3585 days
#11 posted 09-15-2012 12:58 PM
It doesn’t look like a Chevrolet to me. Seriously, I still don’t what it is, but the workmanship is beautiful.
Jack
-- Jack Keefe Shediac NB Canada
sandhill
#12 posted 09-15-2012 03:03 PM
Thanks Matt.
sandhill
#13 posted 09-15-2012 03:04 PM
Jack, I hope to have the wheels on it in a few weeks. Thanks
jackass
#14 posted 09-16-2012 11:59 AM
Hi Sandhill,
That clarified everything. It is a Chevrolet. Truck or Car?
Jack
sandhill
#15 posted 09-16-2012 12:58 PM
Truck of course.
showing 1 through 15 of 30 replies
