| Forum topic by Loren | posted 252 days ago | 358 views | 0 times favorited | 9 replies | ![]() |
252 days ago |
I have a 12” melamine Forrest blade that isn’t bored to fit my That said, the 12” blade would have a higher speed at the |
9 replies so far
#1 posted 252 days ago |
And your current saw is able to accept a 12” blade? Table saw, miter saw, what saw????? -- bill@magraphics.us |
#2 posted 252 days ago |
Table saw. Yes, it takes 12” blades with no problem. The bore is 30mm with alignment pin holes. |
#3 posted 252 days ago |
Thanks. I have an 80 tooth finishing blade (not HATB), but I don’t cut a bunch of melamine. Finish is good to excellent depending on material. I’d use the 10” for no other reason than cost. Rim speed vs: tooth count is a moot point if the cut is acceptable. -- bill@magraphics.us |
#4 posted 252 days ago |
Loren, do have a prescoring unit on your saw? The SCM slider takes a 12” inch blade but you have to change to 10” to allow for the scoring blade when panel cutting. so I would say the rim speed is not an issue. -- Do or do not, there is no try |
#5 posted 252 days ago |
I haven’t found that the higher rim speed cuts that much different. Blades are rated for certain rpms for safety. Too high a rim speed will generate more heat and dull carbide faster. Not a problem with a 12” blade compared to a 10” blade. Do you have a Forrest Hi-AT Melamine blade? If so it’s one of the best blades for melamine. A zero clearance insert doesn’t make it perform any better and I much prefer that blade over a traditional triple chip and pre-scoring blade found on panel saws. It would be cheaper to bore it to fit your saw and different bushings are available to use on different arbors so you can’t lose. -- Few folks really know how to maximize the potential of their tools! |
#6 posted 252 days ago |
It is a Forrest Hi-AT. I have never used it. My saw doesn’t have a scoring unit. It’s a slider. There is a |
#7 posted 252 days ago |
The Hi-AT is a great blade. The problem with the pre-score blades is if the Melamine sheet isn’t pressed flat and makes contact with pre-score blade you get chip out. The Hi-AT doesn’t have that problem. -- Few folks really know how to maximize the potential of their tools! |
#8 posted 252 days ago |
Thanks everybody. |
#9 posted 252 days ago |
If the plate on the 12” blade isn’t thicker than that of a 10” blade, I’d think the 12” would be more prone to flutter, but there are a lot other variables in play. Since the 12” isn’t bored to fit your saw, I’d sell it and look into a 10”....more affordable, and probably more choices. -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1533 |
3550 |
15786 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6159 |
