Bandsaw w/ 2 dust ports which one to use?
Forum topic by JesseTutt posted 09-12-2012 03:32 PM 828 views 0 times favorited 8 replies Add to Favorites Watch
View JesseTutt's profile
JesseTutt
853 posts in 2013 days
09-12-2012 03:32 PM
Topic tags/keywords: question bandsaw dust collection grizzly
On my now Grizzly bandsaw I have two dust ports, one where the blade goes through the bottom guides, and the other at the bottom.
Until I have time (and money) to work up a dust collector setup that would use both ports, I can plug into only one port. Which one would you suggest?
8 replies so far
View Surfside's profile
Surfside
3389 posts in 2076 days
#1 posted 09-12-2012 03:55 PM
I would say on the one where the blade goes through the bottom guides.
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View pintodeluxe's profile
pintodeluxe
5565 posts in 2716 days
#2 posted 09-12-2012 04:03 PM
My Jet port is just under the table, and works well.
View Loren's profile
9935 posts in 3551 days
#3 posted 09-12-2012 04:12 PM
The one on the guides tries to get the fine airborne dust. The one
at the bottom gets the heavier dust that falls. More or less. I’d
use the bottom one and tape over the top one.
View toolie's profile
toolie
2105 posts in 2531 days
#4 posted 09-12-2012 05:17 PM
+1 on upper DC connection.
View Tennessee's profile (online now)
Tennessee
2739 posts in 2417 days
#5 posted 09-12-2012 07:47 PM
On my Grizzly I put my vacuum on the top one and it does fine. You can see the dust get pulled through the insert on the table. I almost never find anything at the bottom of the cabinet.
Surfside
#6 posted 09-12-2012 08:07 PM
You can always use vacuum cleaner when you find some sawdust at the bottom of the cabinet or on the floor.
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 2013 days
#7 posted 09-13-2012 12:40 AM
Both
View Alexandre's profile
Alexandre
1417 posts in 2094 days
#8 posted 09-13-2012 12:51 AM
Both is the way to go.
One for a shop vac if needed, the other for a DC.
-- My terrible signature...
