Problem with my Bosch 1617
Forum topic by Sirgreggins posted 09-09-2012 08:15 PM 750 views 0 times favorited 2 replies Add to Favorites Watch
View Sirgreggins's profile
Sirgreggins
298 posts in 2112 days
09-09-2012 08:15 PM
I just got a Bosch 1617 EVSPK router for my Rokler router table. The fixed base that comes with it of course has the hex key for above table adjustment. I was so excited to get it installed but i’m having a problem. I unlock the motor to use the hex key to adjust bit height. However when i turn the hex key the bit height won’t change. If i take my router out and turn it right side up it can be adjusted. Am i doing something wrong? Please help.
2 replies so far
View Jeff1984's profile
Jeff1984
11 posts in 2069 days
#1 posted 09-09-2012 09:27 PM
Make sure that the cir clip on the lift shaft is in place. I had that same problem and found the cir clip was loose and had to replace it
-- Jeff, Call 911. Wait, I am 911
Sirgreggins
#2 posted 09-09-2012 11:15 PM
that’s exactly the problem. How was the customer service from Bosch? I’m not spending more $ on a clip after $200. haha
