Router as makeshift lathe headstock?
Forum topic by Philip posted 09-09-2012 07:43 PM 3302 views 0 times favorited 14 replies Add to Favorites Watch
View Philip's profile
Philip
1277 posts in 2412 days
09-09-2012 07:43 PM
I have recently been interested in making a few chairs. These designs have spindles that need to be turned on a lathe. I don’t have a lathe and am not interested in using my half finished spoke shave to make a ton of spindles. Is there any way I can make a cradle for my router and turn it into a makeshift lathe headstock? I have seen some where the router is stationary and you spin the wood, can’t you use the router to spin the blank?
Any advice is appreciated, and of this is impossible/ dangerous, then I guess I will try something else.
-- I never finish anyth
14 replies so far
View shampeon's profile
shampeon
1775 posts in 2056 days
#1 posted 09-09-2012 07:50 PM
That sounds incredibly dangerous. 20,000 RPMs is no joke.
You’re better off using a drill or drill press as a makeshift lathe, although the results aren’t going to be as good as an actual lathe. You might look up a local wood turning club to see if you could rent some lathe time from somebody.
View Gshepherd's profile
Gshepherd
1727 posts in 2074 days
#2 posted 09-09-2012 09:29 PM
Totally rethink this one…... Do not even try it….... Find someone local and maybe post on CL what your needing in the Wanted and Tools section for some help….. Even using a drill press is ok but it will put undue wear and tear on the bearings, IMOP of course…. Worst case check out for used one or check our Harbor Freight for a cheap one. But for your own safety do not use the router….
-- What we do in life will Echo through Eternity........
404 - Not Found
2544 posts in 2842 days
#3 posted 09-09-2012 10:01 PM
Bad idea, even the slowest speed on a router is way too fast for roughing gouges. Buy one off Craigs List. If you find it doesn’t suit you, you could always sell it on again.
Philip
#4 posted 09-09-2012 10:50 PM
Noted. Slowest router speed still too fast. Will re- think.
View David Kirtley's profile
David Kirtley
1286 posts in 2871 days
#5 posted 09-10-2012 12:09 AM
That would be less than optimum. Unless being impaled by flying shrapnel is the goal.
No lathe? Lots of plans around for springpole / bungee / bow lathes. They are pretty low tech and cheap. One of my very favorite videos to show just how low tech they can be:
View KOVA's profile
KOVA
1362 posts in 2251 days
#6 posted 09-10-2012 01:44 AM
http://www.youtube.com/watch?v=yXkgnTDRMUA&list=UUU0NNYS71qHYmbXmNHuxoLw&index=30&feature=plpp_video PHILIP: ÉSTE INGENIERO DE SAN FRANCISCO HIZO UN LATHE-HOME-MADE QUE PUEDE INTERESARTE ;-D
SUERTE AMIGO ;-)
-- KOVA, EL CARPINTERO DEL PUEBLO https://www.facebook.com/pages/El-Carpintero-Del-Pueblo/148976618479733
View Dan'um Style's profile
Dan'um Style
14171 posts in 3856 days
#7 posted 09-10-2012 01:57 AM
variable speed electric drill could be used for a lathe…
View KOVA's profile
KOVA
#8 posted 09-10-2012 04:38 AM
View Loren's profile
9766 posts in 3521 days
#9 posted 09-10-2012 06:47 AM
I recommend you don’t mess with trying to make a lathe
unless you have an interest in building machines.
When I was starting out I built a spring pole lathe and
set it up under a plum tree using a bough to power
it. The tool was fun. I got the idea from a Roy Underhill
book.
In any case, you’ll be better off buying a used lathe
and get your parts turned and get on with your project.
You can get lathe jigs that are powered by a corded
power drill, but they are not an especially good investment
considering that affordable and much heavier lathes
are available these days. Machine weight plays a significant
role in successful wood turning.
View lumberjoe's profile
lumberjoe
2894 posts in 2121 days
#10 posted 09-10-2012 01:05 PM
If you are really in a bind, have a VS drill and 50$, you can give this a shot:
View Scott's profile
Scott
121 posts in 2097 days
#11 posted 09-11-2012 02:40 AM
There’s always the drive axle on the family minivan :)
http://www.youtube.com/watch?v=P4qB6n1cm04
View waho6o9's profile (online now)
waho6o9
8070 posts in 2450 days
#12 posted 09-11-2012 02:59 AM
http://woodgears.ca/lathe/homemade.html
Maybe use a drill press?
Philip
#13 posted 09-13-2012 02:25 AM
Great advice. Thanks, I have inherited a shop smith, but it’s on the other side of the country right now… In the meantime I will try some of these ideas, maybe a spring pole- Underhill style.
View Infernal2's profile
Infernal2
107 posts in 2070 days
#14 posted 09-13-2012 02:42 AM
If you have the space and even just minor carpentry skills you can modify the Gingery Lathe plans to take a steady rest. We built one a few years back (the machine shop model) and saved a huge amount of time on the bed casting by using metal tubing.
Probably more than what you want since you have a Shopsmith across country but its an easy and cheap way to get what you want on the cheap.
http://www.lindsaybks.com/dgjp/djgbk/series/index.html
