Gluing particle board
Forum topic by jimhester posted 258 days ago 610 views 0 times favorited 7 replies Add to Favorites Watch
View jimhester's profile
jimhester
11 posts in 1306 days
258 days ago
Topic tags/keywords: joining
Hello All. I have a question about gluing dados in particle board. I’m making some cabinet boxes for my son and am using dado joints where possible. After cutting the dado slots (5/8”), the fit of the full thickness 5/8 is extremely snug. I’m talking drive it in with a mallet snug. I’m concerned about 2 things. One, if moisture from the glue will cause the particle board to swell and break the joint. Two, if I should cut a groove down the middle of the bottom of the dado to allow for squeezout. The joint is so tight that I don’t think the excess glue can get out as it now stands. Also, there is 1/8” overhang on the face frames outside the level of the boxes. Should I space that up with some hardboard before applying the band clamps to help the band clamps keep the assembly square while tightening them? All advice will be greatly appreciated. Jim
-- Jim
7 replies so far
View Grandpa's profile
Grandpa
2381 posts in 847 days
#1 posted 258 days ago
That sounds pretty tight. you might sand a little off the part that goes into the dado. With no grain to worry about that might be doable. You do want those joint snug but we don’t want to break the dado open either. I see your concern. others might disagree but I think I would try a little sanding action on the end of those pieces.
View Nicky's profile
Nicky
422 posts in 2263 days
#2 posted 257 days ago
Gramps (sorry, couldn’t help it) has got it right. Sanding the edges for a slip fit will work. Particle board will swell when glued. Don’t “over-glue” and you won’t have to worry about the squeeze out. An even coat in the dado, and an even coat on the edge of your panel
I’m having some trouble understanding the band clamps. Are you gluing a face frame to the particle board carcass? Are you gluing up the carcass separate or trying to glue everything together?
-- Nicky
jimhester
#3 posted 257 days ago
Grandpa and Nicky….........thanks for your input. I’m going to sand. Too much work done already to chance it now. Yes, I’m gluing the face frame and carcass all at once. I thought maybe that would be the best way to stay square. Jim
-- Jim
View chrisstef's profile (online now)
chrisstef
5299 posts in 1178 days
#4 posted 257 days ago
I wonder if construction adhesive owuld have the same swelling properties as glue? Thinkin liquid nails.
-- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty
View Loren's profile
4895 posts in 1819 days
#5 posted 257 days ago
Skim 1/32” x depth of your dado off the bottom
of the shelf edge on the router table. In the future
you can dado 1/2” and rabbet the shelves to fit this
way.
In terms of rabbet tongues interfering with band clamps,
you are correct.
jimhester
#6 posted 255 days ago
I just got back to the project last night. Turns out that Mother Nature is my “frienemy”. When I retried the joint to see how much to sand off, it slipped right together with hardly any effort. I didn’t know why until I realized that when I was working on it last week, the weather here was hot and humid. Now it’s much cooler and far less humid. The only thing I can figure is that a few days of high humidity had the partcleboard swollen enough to cause that overtight fit. I guess I’ll try to get it sealed as soon as possible after glue-up while the humidity is low. It sure would be nice to have a climate controlled workshop.
Speaking of glue-up, I’m thinking about trying the Titebond Extend glue because it has a slower setup time. Short of having to heat hide glue, does anyone have any suggestions?
I was discussing the tight dado situation with my wife. She said “Why don’t you just nail it together?” Before I could explain why, she said that when she was a little girl her dad made her a great nightstand with just a handsaw, hammer and nails, and some purple paint. I helpfully (I thought) suggested that she assign a number to all the “my dad in shining armor” anecdotes and it would save us both a lot of time to just say the number instead of repeating the whole thing. I assume that she’s busy working on that idea since she hasn’t said a word for several hours now.
-- Jim
TopamaxSurvivor
13194 posts in 1847 days
#7 posted 255 days ago
And they think they are punishing us when the give the silent treatment! :-))
