Delta Table Saw - blade alignment
Forum topic by benji posted 252 days ago 565 views 0 times favorited 4 replies Add to Favorites Watch
View benji's profile
benji
1 post in 253 days
252 days ago
Topic tags/keywords: blade tablesaw
I tuned up my Delta 10”contractors tablesaw which included truing the blade. I followed the instructions in the Delta manual, loosening the trunnion, etc. I got the saw blade aligned, within 0.003”, front to back. When I reinstalled the zero tolerance sawblade insert, I noticed that the blade did not fit in the zero-tolerance insert kerf; it had moved maybe 1/32” to one side, so I had to make another cut in the insert. It seems to make sense that after moving the trunnion I suppose you are actually setting up a new blade tracking pattern. Would like to hear from the experts if my assumption is true.
View ajosephg's profile
ajosephg
1718 posts in 1726 days
#1 posted 252 days ago
You are correct, that is what happens.
-- Joe
View knotscott's profile
knotscott
4181 posts in 1541 days
#2 posted 252 days ago
I’d be more concerned if you moved the trunnion and the blade location didn’t move.
820 posts in 659 days
#3 posted 252 days ago
You got it right, don’t forget any jigs and so on will also be off that same amount, like a panel sled, tapering jig…whatever.
-- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard)
View NiteWalker's profile
NiteWalker
1467 posts in 742 days
#4 posted 252 days ago
Yep, you did good.
I have a delta contractor saw too and aligning it was a bear. I ended having to shift both trunions and it took a few days of on and off trying, but i have it to .0015 now and I’m happy with that.
