Finish advice on Spraying GF Milk Paint
Forum topic by chip73 posted 09-07-2012 01:42 AM 1290 views 0 times favorited 4 replies Add to Favorites Watch
View chip73's profile
chip73
55 posts in 2183 days
09-07-2012 01:42 AM
Topic tags/keywords: finishing sanding
I am getting ready to do my first project using my new Earlex 5500. I will be spraying GF Milk Paint on Poplar. I know I am looking at putting on light coats, but do I need to sand between coats and if so what grit? Looking forward to a new experience and increasing my skills. Thanks for the help.
-- Facts are stubborn things; and whatever may be our wishes, our inclinations, or the dictates of our passions, they cannot alter the state of facts and evidence.
Gerald Thompson
919 posts in 2204 days
#1 posted 09-07-2012 01:46 AM
GF Milk Paint is not real milk paint. I have brushed it on and never sanded it and it cmae out fine.
-- Jerry
View casual1carpenter's profile
casual1carpenter
354 posts in 2445 days
#2 posted 09-07-2012 03:03 AM
Chip, I am sort of in the learning stage with my Earlex 5000, but I can tell you that even at my entry level I am glad I bought the system. I would suggest that both GF and Earlex were both patient and helpful when I called for support or clarification. There is also an LJ member that I think is a tech for Earlex who is also very helpful and knowledgeable.
View KarenW's profile
KarenW
131 posts in 2158 days
#3 posted 09-08-2012 08:06 PM
I use General Finish paints a lot in my shop and I thin slightly and spray. Two coats of primer, usually 3 coats of paint (depending on the color). Normally I sand after the second coat of primer and after the second coat of paint using 220. After the third coat of paint, if I have any areas not smooth enough, I use a green pad (scotch-brite) and then hit it with a top coat of lacquer.
-- Happiness does not come from doing easy work but from the afterglow of satisfaction that comes after the achievement of a difficult task that demanded our best. --Theodore I. Rubin
chip73
#4 posted 09-09-2012 01:10 AM
Thanks for all the advice, can’t wait to start.
