Contractor Saw Switch
Forum topic by Dchip posted 09-06-2012 06:23 PM 2234 views 0 times favorited 8 replies Add to Favorites Watch
View Dchip's profile
Dchip
271 posts in 3125 days
09-06-2012 06:23 PM
Topic tags/keywords: question table saw wiring
I just replaced the switch on my Ridgid R4510 (http://www.ridgid.com/Tools/R4510-Table-Saw/en/index.htm) after about 2 years of hobbyist use. Not being electrically-inclined, it looks like some sort of internal fuse was blown (one of the two white wires, not the red or black). I was lucky to find this and replace the part for a whopping $13, and my saw is back up-and-running.
My question – is there something I did to cause this? That I can do to prevent it from happening again? I have a 9ft., 14-gauge extension cord to the saw. It’s rated at 15 amps (same as saw), but I’ve read that the saw can surpass this on start-up. I also live in a pretty old building with probably 1930’s wiring if this matters. I appreciate any and all learnin’ you guys can send me.
Thanks.
-- Dan Chiappetta, NYC, http://www.9x7woodworks.com
8 replies so far
View Paul C.'s profile
Paul C.
154 posts in 3118 days
#1 posted 09-06-2012 11:36 PM
I am in the same situation, as my saw is now permanently on. Not very safe, as I have to it and unplug it to start and stop it. I am getting better with handsaws now. I look forward to others input.
View knolltop314's profile
knolltop314
1 post in 1961 days
#2 posted 09-06-2012 11:43 PM
fwiw, page 8 of Operator’s Manual indicates your 14 gauge ext cord should be sufficient out to 25 ft
-- Michael
View toolie's profile
toolie
2101 posts in 2501 days
#3 posted 09-07-2012 02:35 AM
why on earth did YOU fix it? if you’re the original owner, is it under it’s 3 year warranty? and did you register it with the LSA (lifetime service agreement)?
View JesseTutt's profile
JesseTutt
853 posts in 1983 days
#4 posted 09-07-2012 03:09 AM
I would suggest that you upsize to a 12 gauge extension cord. Less voltage drop for a given length.
I replaced the toggle switch on my Delta saw with an aftermarket start / stop switch (rockler). It is much safer than feeling around under the table to find the toggle switch and turn the saw off.
View IsaacH's profile
IsaacH
128 posts in 1969 days
#5 posted 09-07-2012 03:11 AM
The fuse did its job and you were drawing too much current through the switch. This could either be by bogging the motor down (like by feeding the wood too fast) or by the voltage being too low. The low voltage is where the power cord length and guage can come in to play. Make sure that the ends of the cord are free from corrosion. If that checks out of, check the building voltage. You mentioned the building being old. it should be within 10% of the rated voltage of the saw. If its more than 15% too low, call an electrician immediatly.
The low voltage is possible, but the motor being bogged down or even physically stopped with the power on is much more likely.
-- Isaac- Decatur, GA - "Your woodworking....NOT machining parts for NASA!!!"
Dchip
#6 posted 09-07-2012 01:31 PM
Thanks everyone for the input. My last cut before it died was some 1/4” plywood (it didnt crap out mid-cut), so I dont think that did it. I have put the motor through its paces with some 8/4 maple and purpleheart in the past though. The only problem with 12 gauge cord is they dont really make it under 25ft. My shop is small so the extra length would be wasteful, or even counterproductive. Good call on the owner’s manual knolltop, I had it out looking for the parts list but never thought about looking up electrical specs. I replaced it myself, toolie, because I thought I could handle it and it would be a learning experience. Probably wasted some money buying the part myself, but I avoided a long downtime and didnt have to haul the saw to a service center. I wouldn’t be surprised, isaac, if it actually was my building. Still some investigating to do. Thanks again everyone, it really helps to have the advice of those who have come before and know more.
View MrRon's profile
MrRon
4564 posts in 3116 days
#7 posted 09-07-2012 04:54 PM
Buy 25’ of #2-12 appliance cable with ground, a plug and receptacle for the ends.
View Grandpa's profile
Grandpa
3259 posts in 2548 days
#8 posted 09-08-2012 01:46 AM
I actually bought a 12 ga cord that is about 6 or 8 ft long. It is the flat style though if that matters. They are available.
